Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 476 posts ]  Go to page Previous 142 43 44 45 4648 Next
PostPosted: Sat May 30, 2015 9:40 pm
Don't urge Hans! If he sits at his computer all day long to finish the new version he may become constipated, too.
Found a special case of the '10 sec waveform display getting stucked' problem:
  1. default settings, default ST window
  2. now click the arrows to have the waveform shown on the right side
  3. increase to 10 sec display
  4. re-click the arrows to have the waveform back on the left -> it gets stuck
After restarting ST, so that one has 10 sec right from the start, everything is fine, though.
PostPosted: Sun May 31, 2015 1:36 pm
Is that with the latest beta? I just tried this and it keeps working...
PostPosted: Sun May 31, 2015 3:33 pm
Hans,
Is it possible to get an Linux version of the betaversion?
Here they are; 2nd is with GUI:
http://www47.zippyshare.com/v/U2T552Nw/file.html
http://www47.zippyshare.com/v/euuJi0P6/file.html
PostPosted: Sun May 31, 2015 3:39 pm
Hans,
I did take a quick look with ldd and saw that this is a 32-bit version. Can you mix a 32-bit client with a 64-bit jack?
PostPosted: Sun May 31, 2015 4:36 pm
Yes, beta 51, reliably reproducible here. Also note that ST will save the waveform display time as 10 sec when exiting. However after restarting ST it's automatically reset to 5 sec and therefore working fine again. Btw, hovering the mouse pointer over the waveform shown on the left will make it jump a bit further (no matter if stucked or not).
Maybe this problem depends on window size or position or something?
PostPosted: Sun May 31, 2015 6:36 pm
BETA 761-052A
Windows stand alone: http://www.stereotool.com/download/ster ... 61-053.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 61-053.exe
VST 32bit: http://www.stereotool.com/download/vst_ ... 61-053.dll
- Make Limit before Compress switchable in old compressor as well
- Fixed Linux 32 bit version for Ubuntu 13/14 (probably a stack overflow issue caused by too aggressive optimizations)
- New (Analog mode) Limiter was broken in low quality mode
- Crash reported by Peter Kluyver - Not enough information. Occurred in 761-035, crash in ntdll.dll at 0x5b72E (exception 0xC0000005), not handled by Stereo Tool. No streaming via VLC used.
- Added second Multiband Compressor
- Added resampler for normal output to fix 2 output on different sound cards problem (for example FM on sound card and streaming via VAC/VB Cable).
- Added auto-restart behavior if buffers get too full or too empty.
- Added upto 10 seconds of audio delay for HD radio.
- Added support for built-in GUI skins
- Added option to show beta version number in title bar
- RDS: Added RT+ support.
- RDS: Fixed time zone 30 minute offset problem - viewtopic.php?f=6&t=5941&p=28209#p28209
- GUI: Improved display for bigger screens.
- GUI: Increased maximum waveform display from 3.2 to 5 seconds.
- GUI: Made line around Phase Delay in bottom display less bright.
- GUI: Bug fix: Composite clipper used but not registered warning wasn't shown.
- GUI: Save settings .ini when saving the settings to any file.
- GUI: Fixed delay of Delossifier in display.
- GUI: Fix 'Load default values' question for MB #bands change.
- GUI: Improved Compressors gate and limiter display (new Analog mode only).
- Singleband Compressors: Don't allow Threshold values below 0.5 dB
- Compressors: Made a new Compressor implementation ('Analog'), based on the behavior of water pressure control systems and hydraulic automatically closing doors. Sounds better and uses far less CPU load.
- Compressors: Made new Limiter (only used in combination with new compressor mode).
- After-AGC Singleband Compressor: Added new Analog compressor mode with new limiter.
- Final Singleband Compressor: Added new Analog compressor mode with new limiter.
- Multiband Compressor: Added new Analog compressor mode with new limiter.
- Multiband Compressor: Band Link did not work in 3-band mode.
- Multiband Compressor: Added Freeze/Gate for all bands combined (Analog mode only).
- Multiband Compressor: Fix frequency band shift (10%, since 7.51 or 7.60).
- Multiband Compressor: Fixed a filtering issue when using Density Drive > 1.00
- Improved CPU performance a bit, on multiple places (clipper, GUI).
- Small performance optimizations.
- Optimized synchronization between sound cards code - factor 5 CPU load reduction.
- Multipath Clipper: Made it stricter (use Smoothing mode)
- Bug fix: Saving FM sound card issue in VST: viewtopic.php?f=2&t=6027&p=29066#p29066
- Bug fix: Compressors: When gate is set to -99 dB, release stops working.
- Bug fix: GUI: Threshold and knee were labeled 'Speeds' instead of 'Levels'.
- Fixed 'uninitialized memory read' warnings (reported by Intel Inspector XE).(
- ProppFrexx integration: Added RDS control via VST (canDo, vendorSpecific)
WAITING FOR FEEDBACK 7.70:
- Wait for Matt Aaron's feedback about HD synchronization
TO DO 7.70:
- 10 seconds display gets stuck if in bottom left small display
- Exception NAN in Gray display (Edgar)
- Start of some presets is bad on load (too much gating) - fixed
- Flat Frequency Response is broken in Analog MB mode!!! Fix! (And adjust all presets that are using it to compensate)
- Memory leak occurs in all plugins
- Wait for Diggy Down FM (TURN DECLIPPER ON!) and Jesse Graffam's final streaming/AM/FM presets; answer from Nikolay Vachev; include Uptown FM preset, Sjoerd Wijdogen
- Check RDS time zone issue - apparently still not ok in Brazilian time zone
- Adjust Simple preset levels
- Adjust FM BS412 preset levels
- Wait for feedback on which presets to keep/remove/reorganize
- Release
TO DO 7.71:
- EQ with 'standard' sliders.
- Memory leak in Generic plugin (reported by Franciszek)
TO DO WITH LEIF:
- Stokkemask: try if I can move the data a few samples to make 2nd smoothing step unnecessary.
How to use RT+ in RadioText
Put \+xx before and \- after an item
where xx is an RT+ type number (00-63).
Instead of a number you can also use the codes
WW or UR for an URL (type 29)
AR for Artist (type 04)
TI for Title (type 01)
So for example:
Now playing \+ArMadonna\- - \+TiLike a Virgin\-
You can use at most 2 codes. For now, codes are transmitted for ALL the texts, so this only works properly if you have a static RT text. I might change that later.
PostPosted: Sun May 31, 2015 6:38 pm
Hans,
I don't know, but I'll post the 64 bit versions soon enough when the build the release candidate. I hope to be able to do that tomorrow (still waiting for a few presets...)
PostPosted: Sun May 31, 2015 6:42 pm
Where did you add making Limit before Compress switchable? If it's the old multiband compressor, I don't see it.
PostPosted: Sun May 31, 2015 6:47 pm
Nevermind, I am truly a mess sometimes. I found it.
PostPosted: Sun May 31, 2015 6:49 pm
The saving issue (values cut off at 5) is fixed now. I also see the problem now; the right line (1 pixel) does get redrawn but for some reason the scrolling doesn't work. Will check this.
