I hate to buck the trend here, but after running version 7.60 for a while, I'm just not satisfied with the sound and am going back to version 7.51. I'm using the dsp version. I went back and forth between versions a couple of times, resetting all settings, then loading the preset. 7.60 just doesn't have the natural sounding presence of 7.51. It's like things are under a slight veil or haze with version 7.60. I know hearing is subjective, but these are my heartfelt impressions with the newer version.
Thanks, I've received your settings file and I've just tested them. And found a bug in version 7.60.
There is one big difference in the sound between version 7.51 and 7.60, and that's caused by the Phase Delay filter. The settings that were made in version 7.51 are misinterpreted in version 7.60 which may cause all kinds of weird effects - basically the wrong settings are telling the processor to move some sounds backwards in time, which isn't possible! So, this is a bug.
If you turn this filter OFF the sound is very similar. Can you check if that fixes the difference that you're hearing? If in version 7.51 you prefer the sound with this filter enabled, then the settings can be converted to version 7.60 but it will have to be done manually...
