1.Something is wrong again with the Pre-Emphasis indicator ( not exist )
I see it normally here...
2.Also RDS text is too weird (flattened, compressed) in the Configuration->FM Transmitter ( i guess it`s the RT there and below is the Date/time)
Not enough space, I'll keep it this way though so you can at least see that something is being broadcast - if your window is big enough, you can read it.
3. Stereo boost indicator changed - now both are nearly yellow ?
Hm not the best color indeed, visibility is bad.. Bojcha?
4. Bass Boost - both indicators are grey ?
Hm... I prefer brown there because to me bass is brown, highs are yellow... This may not make any sense though. But I think it should have a similar color to the bass clipper on the right, which is also brown. Bojcha, what do you think? (It's your skin
