A few weeks ago Bojcha reported the following issue: Bass sounds better without 'Advanced Bass Distortion Protection' enabled.
I found a bug in the code (or actually a few bugs) and I've fixed those. The result is the version linked below.
One warning though: The highs are affected by the louder bass. I discovered that there's a bug in the highs filtering (in version 6.20 and above), that's probably hurting the quality of the highs (and at least it makes them softer than they should be) - intermodulation distortion is happening TWICE, which is of course very bad. If I fix this bug though, the lows and mids are ducking again when there are loud highs. I think I know how to fix it (clip the amount of ducking), but it's not implemented yet.
In this version, in my measurements I saw an increase of 1.4 dB in the bass region (biggest boost is around 100-150 Hz), and a drop of 0.2 dB above 3700 Hz.
EDIT: Oops, I see that I've compiled a version with drops instead of lower highs! Well, the next version will have a configurable maximum drop level.
Stand alone:
http://www.stereotool.com/download/ster ... 31-001.exe
DSP:
http://www.stereotool.com/download/dsp_ ... 31-001.exe
VST:
http://www.stereotool.com/download/vst_ ... 31-001.dll
