- Limiting & Loudness: Hm, this one also contains Hard Limit, BS412 and the singleband compressor/limiter. I think I'll leave the name as-is for now, in the redesign all these filters will end up in differnent windows.
Ok, that's right
- Final Clipper: Fixed (in code, will be in BETA017)
Ok!
- Clip in MB: Only works if you lower the slider above it! (It's turned off when that's set to 1). Actually I wanted to remove these few sliders a long time ago already, but some people seem to use - and like - them (I don't).
I agree that it should be removed, given that there is an end after clipper.
- AEHP: It works, but it doesn't do much for non-FM signals so you could probably just as well turn it off...
Yes, working and listening. But what I mean is that when work is not reflected in the movement of the blue bars, like the rest of the indicators.
Thank Hans !
