Site Admin |
Stereo Tool 10.10 is released!
Stereo Tool 10.10 is a massive change compared to the previously released version, 9.92. Should you encounter any issues after installing version 10.10, you can always revert to 9.92 - but please notify us of any issues that you encounter!
You can download it here: https://www.thimeo.com/stereo-tool/download/
Changes:
- All Stereo Tool-based products migrated to new user interface.
- New user interface and web interface are completely reorganized.
- New GUI: Added display for active sample rate in plugins.
- New GUI: Added Persistent display of CPU, buffer fillings.
- New GUI has been greatly improved since the (very early) 10.00 release in ST-Enterprise. Too many changes to list here.
- New GUI: Added metering overview screen.
- All Stereo Tool-based products migrated to new I/O layer. The BIMP can now be used in Stereo Tool DSP and VST plugin versions!
- New I/O framework: Increased target buffer filling for synchronization by 1 block, making it identical to the old framework, and more logical.
- New I/O framework: Add 1 extra block to MME/Wasapi/Kernel Streaming based on buffer size, to prevent almost certain hiccups at buffer size 0.
- New I/O framework: Enabled resampling in new I/O mode when Auto is selected even if buffers are very small.
- New I/O framework: Add Jack support, dynamically loaded only if it is installed.
- New I/O framework: Bug fix: If the buffer ended up in the area where it could be either too full or empty, it could get stuck there.
- New I/O framework: Bug fix: Possible crash on exit when sound card was unresponsive.
- New I/O framework: Lots other of fixes, additions and improvements since the preliminary version 10.00.
- Web interface: Reduced startup data usage from around 3 MB to 310 kB.
- User logins enabled for both native and web interface for Enterprise, STX, ABE and MicroMPX builds.
- User logins: Added View-only rights.
- User logins: Loading and resetting parameters now ignores parameters that you don't have access to; load for editable, save for visible.
- User logins: Export of saved presets is now filtered as well for login rights (not visible = removed from export).
- User logins: Preset selection links in web interface are filtered for access rights.
- Added simple password protection for non-Enterprise/STXtreme builds. Incompatibile with old password mechanism, after updating old password will be gone.
- RDS: UECP: Added support for group 0x30 TMC encoding as used by Broadcaster Traffic Consortium (BTC) in the US/Canada (waiting for certification).
- RDS: UECP: Added support for ClockTime messages (time zone, clock offset, turn on/off).
- RDS: UECP: Added option to block access to setting any text fields (PS, RT, PTYN) to protect against hackers on open ports used for among others TMC data.
- RDS: Changed RT+ order based on advise from ChatGPT, might improve handling of updates on some receivers.
- RDS: Restored old RadioText A/B behavior for non-UECP inputs to how it worked before version 9.92/10.00; new behavior was causing issues on some receivers.
- RDS: Move ECC en LCC from Advanced RDS to normal RDS.
- RDS live data visible in web interface.
- Web interface: Cursor keys moved both slider and whole page.
- Some password protected settings could still be changed from the web interface, fixed.
- Web interface: Improved screen reader support, preset manager still to be finalized.
- Web interface: Removed unnecessary parametric EQ communication to web interface (was updating the graphs on each redraw).
- Web interface: Increased maximum whitelist size (from 1024 to 8192 characters).
- Web interface: Password page does no longer ask to store passwords for other users.
- Web interface: Lots of smaller improvements.
- Web interface: Added support to send it through a proxy (add /stereotool/ in the URL at the end of or after the proxy link).
- Settings are now automatically saved if you don't touch the native or web interface or STXtreme front panel for some time.
- Memory usage optimized reduced a lot (hundreds of MB's in some versions).
- Memory usage: LQLL mode in Winamp and VST plugins only instantiated when needed.
- Memory usage: Optimized for cache behavior (small effect, 1% better performance).
- Changed how plugins access their host information.
- Dante: Show IP address in GUI.
- Updated Raspberry Pi SD card image to be nearly read-only. (todo: post this)
- Bass EQ: Add go-to level for silence.
- Presets: Split RDS from other FM settings, so they can be loaded and saved separately.
- Phase inversion detection: Added threshold setting to make it more sensitive, it wouldn't switch on most stereo music.
- Added "Difference" mode to equalizer.
- Lots of parameters and pages have been renamed, to make it clearer what they do.
- Added optional console window for debugging purposes.
- Relay: Added RDS method A switching, and RT.
- Improved password protection code (should now be safe).
- Compressors: Dynamic speeds: Added checkbox to allow attacking immediately at highest possible speed, which might sound better (AGC, compressors).
- Using Jack or not depends on the file name now - if the name contains "jack" it uses it, if it contains both "jack" and "alsa" it uses both!
- VST2 resizing added, risky...
- VST3 plugin is now a SingleComponentEffect, this should fix rendering issues in WaveLab.
- Added possibility for resellers to block access certain parameters (.st.gui_override).
- "Acceleration" slider under Auto EQ/Bass EQ fixed (behavior was broken).
- Streaming allows = character in mount point.
- Streaming potential exception on closing fixed when there was invalid input data.
- Preset loading and saving completely rewritten.
- Bug fix: Multiple-second hanging on loading certain presets; MicroMPX NIC addresses were saved as "" instead of "Automatic".
- LiquidSoap supports the Generic plugin, and MicroMPX is added to the Generic plugins.
- Short-term half-price (3 day) license increased to 4 days, after getting multiple requests for that.
- Changed Stereo Tool license encoding.
- Console version: Show license errors.
- WatchCat: No longer goes to background mode on Mac when window is not on front, caused it to run really slowly.
- Added DHD mode to run inside DHD consoles.
- HD processing: Added de-emphasis filter, sounds good on low bitrate HD stations.
- VST plugins: Added unlicensed warning in top bar.
- Preset files now contain the word "(off)" for settings that are in an off mode, which allows for future changes of the limits.
- New GUI: Changed precision of up/down cursor keys.
- GUI/Web interface: Fixed unicode behavior.
- GUI/Web interface: Added license warning bar on top of GUI.
- GUI: Made performance display meters more responsive.
- GUI: Added anti-hysteresis to CPU usage popup to prevent it from blinking extremely fast.
- GUI: Tray icon is restored if Windows Explorer crashes.
- GUI: Bug fix: Fixed flashing of some meters (bass meters, limiters in compressors).
- GUI: Changed direction of attack/release speeds (renamed to time); more logical.
- GUI: Improved license message (Scheduler unlicensed instead of "Invalid license").
- GUI: Disabled Progressive ratio if Max is set below main.
- GUI: If an error message keeps popping up, we snooze it for 30 seconds.
- GUI: Split I/O settings into I/O (sound cards, streams) and Broadcasting (the signal itself) settings. Some settings (BS412 audio settings) are moved to Processing.
- GUI: Added warning if Hear is on anywhere (Difference to be added later).
- Bug fix: Encoding MicroMPX from Stereo Tool at 44.1 kHz with block size 2048 and "Ignore low frequencies" set to 38.4 failed.
- Bug fix: AZIMUTH was loaded as part of Processing instead of Repair.
- Bug fix: Jack versions crashed when using input 2 (must have been since at least version 9.00).
- Bug fix: NAN's when changing number of bands (Auto EQ, Bass EQ, Multibands).
- Bug fix: Dehummer could write GUI data outside of memory if used for more than 2 channels.
- Bug fix: Possible crash fixed when using multiple instances.
- Bug fix: HighInYourFace GUI didn't display anything at block size 2048 with Quality > 100%.
- Bug fix: Preset dates were shown in UTC instead of localtime.
- Bug fix: CPU settings reset/load sometimes behaved incorrectly.
- Bug fix: Clipper still looked at some frequency settings that are disabled in Legacy highs gap mode with other legacy setting disabled.
- Bug fix: R128 multi-step processing could end up in an infinite loop (WatchCat/command line/generic plugin).
- Bug fix: Absolute Highs: Small fix that may have some (minor) impact on the audio.
- Bug fix: Some parameters that should only be in the .ini file were saved on full exports (instances, disabled warnings).
- Bug fix: Diversity delay did not work in multi-instance version.
- Bug fix: Empty .wav files caused infinite loop in command line version.
- Bug fix: Linux/Mac: Thread killing could cause a fatal exception (old issue, 9.92 and earlier versions as well).
- Bug fix: Encoding MicroMPX from Stereo Tool running at 44.1 does not work on ARM; now disabled.
- OBS: GUI got bigger every time it's opened in OBS. Workaround added.
- Disabled FM Analyzer in this build; we need to make a separate product for that.
- Overall code cleanups.
- Presets added and updated.
- ST-Enterprise: Added built-in Kantar watermarking, version 8.1, Kantar certified.
- ST-Enterprise: Added built-in Intrasonics watermarking. (contact us if you need it in STXtreme)
- Kantar/Intrasonics: Support separate watermarks for FM/HD.
- ST-Enterprise: Bug fix: After restarting, Nielsen PPM encoding could show an error message.
- ST-Enterprise: Bug fix: Instances > 1 crashed when loading very old settings (from before it was officially released), an early beta customer ran into this.
- ST-Enterprise: Bug fix: Did not work properly (lost settings) in service mode.
- ST-Enterprise: All instances wrote presets to the same folder. Preset list for instances > 1 will be empty after update.
- STXtreme: Support for 2x FM or 1x FM + 2x HD processing. (more to be added soon; contact us if you need it)
- STXtreme: Added built-in Nielsen PPM watermarking, Nielsen certified.
- STXtreme: Added built-in Kantar watermarking, version 8.1, Kantar certified.
- STXtreme: Supports for old and new (to work around chip availability shortages) hardware versions.
- STXtreme: Front panel: Always open front screen on home page after restarts.
- STXtreme: Front panel: Sound cards and sample rates can now be set.
- STXtreme: Front panel: Presets can be loaded.
- STXtreme: Front panel: Added 2-finger scrolling (currently only affects preset list).
- STXtreme: Front panel: Added RDS PS display to top bar.
- STXtreme: Add setting for signal (pre/de-emphasized FM, streaming/HD) selection for HD output.
- STXtreme: AES frequencies read from driver instead of settings file.
- STXtreme: Installer sets the time zone to UTC (causes 3 reboots when updating from an older version).
- STXtreme: Explicitly request to update time via NTP.
- STXtreme: Enabled IceCast.
- STXtreme: Added preliminary support for AES67 on Input 2, not tested.
- WatchCat: Add macOS ARM M1/M2 version.
- MicroMPX: Bug fix: QOS never worked properly on Windows. Now it should work when running ST or MicroMPX in Admin mode (DSCP46/Expedited Forwarding).
- MicroMPX: Buffering behavior completely rewritten; this should work better (on startup mainly).
- MicroMPX: Temporary speedup of synchronization after switching to a new stream, to be in sync with other decoders much faster.
- MicroMPX decoder: Added option to replace the existing RDS data (built-in RDS encoder).
- MicroMPX decoder: Ancillary data displayed in web interface.
- MicroMPX: GPO ancillary data encoding standardized between vendors, protocol for future enhancements defined, see manual Appendix 3.
- MicroMPX: GPS: NMEA timing changed because it failed in Brazil, probably caused by the number of GPS satellites in view.
- MicroMPX: GPS: Decoding is now possible using 1PPS pulses + the system clock instead of NMEA (system clock must be less than 0.4 seconds off; untested).
- MicroMPX: GPS: Added /dev/ttyACM0 for the hardware that we provide for GPS synchronization.
- MicroMPX: Optimized license mechanism, works a lot faster and with less memory now (for new keys).
- MicroMPX: When switching between streams, if we are just below ideal buffer filling we just keep writing there instead of creating a gap.
- MicroMPX: Added stream reset on turning on/off; without that decoders try to adjust for a delay in packet receiving.
- MicroMPX: Added option to reduce webinterface bandwidth.
- MicroMPX: Added workaround for weird behavior in NMEA datastream from a specific Navilex GPS receiver (might be a Linux bug as well).
- MicroMPX: Bug fix: Multicast didn't subscribe on startup.
- MicroMPX: Bug fix: Thread could briefly go to 100% CPU usage.
- MicroMPX: Bug fix: Logging was causing a memory allocation in the call to get the current time.
- MicroMPX: Bug fix: Could hang on close.
- MicroMPX: Bug fix: Fixed 44.1 kHz sample rate calculation bug, which could cause warnings to be displayed - had no real impact.
- MicroMPX: Added 44.1 (176.4) kHz version to enable HD synchronization; not compatible with normal version. Encoder in ST and decoder only so far.
- Only use for testing, rename the binary to contain 176400 in the file name. Library versions have initialization options.
- MicroMPX: Latencies down to 10 ms are now achievable. Not yet released; can potentially cause performance issues with existing hardware decoders.
- MicroMPX libraries: Added callback for when RDS data is received in the bitstream.
- MicroMPX libraries: Added password hashing.
- MicroMPX AM Reprocessor: Added NRSC AM mask.
