Phoenix: Just a quick check to see what it does.
Winamp DSP plugin:
http://www.stereotool.com/download/dsp_ ... 20-001.exe
Stand alone version:
http://www.stereotool.com/download/ster ... 20-001.exe NOT AVAILABLE
VST version:
http://www.stereotool.com/download/vst_ ... 20-001.dll
VST version (No SSE2):
Command line version:
Linux command line version:
http://www.stereotool.com/download/ster ... ETA620-001 NOT AVAILABLE
Linux GUI version:
Extra low frequency AGC added directly after current AGC. (Actually it might be better to place it AFTER multiband.)
Note: This also reduces bass artifacts at low latencies! (For that it must be placed BEFORE Multiband!)
- Stand alone version not available because I'm in the process of adding an interesting new stand alone feature...
- I hear some artifacts at low latencies that I didn't expect. Will have to check what's causing it.
- 'Remove remaining peaks above' for new 2nd filter still uses setting for 1st filter!
Edit: Hint: Good settings seem to be:
- Up speed: ~ 175
- Down speed: ~ 500
- Target output level depends on Multiband settings (if you select 'LIMIT' instead of 'COMPRESS', it makes little difference - lower = less artifacts at low latencies).
At low latencies, it also helps a lot (also in 6.10 by the way) to reduce 'But never raise band 2 more than' - for example to 200%. The bigger this difference is, the more artifacts the AGC can cause (ok, it's not the main source of artifacts - but with this new filter the Multiband and Loudness artifacts are reduced a bit, and the AGC artifacts are noticeable).
