I don't know (still have to check) if the up speed of the AGC differs between stand alone and plugin versions (if it does, it's probably caused by the different input sample rate!).
I double checked this ..
In standalone any samleprate used, AGC speed is always same, In DSP however AGC is much faster in any case. Even i think multiband is faster too, but i am still not sure.
I've listened carefully to lots of FM stations lately, and I noticed that they do something that I don't - if there's a lot of bass the rest of the sound gets reduced a bit. And actually that's probably less annoying than the unclear highs.
Heh.. That's what's bother me for long time. That's why i said that third and second band in agc is not complete solution and RMS correction is needed somewhere to correct this. In my last presets i use all 3 bands in AGC, but much lower then default (rise 50-53% and rise max 170-200%) to compesate for High energy bass songs to stay as is.
I think that I need to put a singleband AGC somewhere in the chain. Could be directly after the current AGC, or maybe after Multiband (directly after the current AGC might be easier to configure).
Well .. i still think that some AGCing is needed after multiband. In v.5.10 we tryed 2nd AGC right after 1st. This AGC should be driven more by RMS. For start, singleband AGC will be good same as this one at start of chain.
Also i think "Bass boost" filer need one option/function.
- When i turn off "Preserve louder peeks" i get much better results, because i can always limit lows at same peek-level"
That's always ~1dB lower then 0dB. So rest of sound is much less affected to be distorted by lows.
But, When some House song comes with "Bass-only" part, that space from ~1 to 0dB is wasted.
So... what is needed is some fast leveler (-2 to +2dB) to detect when no other sounds is preset (or present much less), to rise it up fast and when mids and highs comes, to put it fast down again.
lol did i explane it right?
