Agree with The BIMP, and that's something that I do want to add (also as a separate sound card input so you can talk through your broadcast from any playout system, even if that playout system doesn't support any microphone input).
But that's the only thing that seems useful? Besides for The BIMP, the 2nd input can only be used for backup, RDS or SCA input. That doesn't seem particularly useful. Similarly, the other outputs can be used for FM, streaming and low latency - I'm not sure that that's useful either.
But yet, The BIMP does need to be added, I agree about that.
Yes, but if you add BIMP, then it would be good if you could also provide it directly as input to the VST version. This would make it possible, among other things, that you could pass language and music separately in a multi-track DAW. This option does not work if it works only with a separate sound card input.
From my point of view, this use case would be comparable with side chain scenarios.
