Post new topic  Reply to topic  [ 166 posts ]  Go to page Previous 113 14 15 16 17 Next
PostPosted: Fri Apr 26, 2019 3:52 pm
BETA029 is available!
But not ARM versions; both are missing.
Sorry, the word "BETA" was missing in the links. Fixed.
PostPosted: Fri Apr 26, 2019 7:25 pm
Thanks! Trying to execute that in 32 bit Rasp says:
root@micrompx:/opt/uMPX# ./MicroMPX_Decoder_ARM32_BETA924-029
-bash: ./MicroMPX_Decoder_ARM32_BETA924-029: cannot execute binary file: Exec format error
Earlier binaries worked well.
BR,
Janne
PostPosted: Fri Apr 26, 2019 9:16 pm
Ow! The upload script for beta's was mixing up the ARM and x86 Linux builds :(
I've just fixed and reuploaded it, it should work now.
PostPosted: Sat Apr 27, 2019 6:15 am
Thanks, now it works. And now tests running with 576k. Looks (and sounds!) good.
-Janne
PostPosted: Sat Apr 27, 2019 6:47 am
Sorry Hans
EXCEPTION OCCURRED IN ProcessingChain Thread (Exception 0xc0000005 at address 0x7ff7e0eebf21, read/write=0, r/w location=0x0). Offset-info: 0x7ff7e35ad379
EXCEPTION OCCURRED IN ProcessingChain Thread (Exception 0xc0000005 at address 0x7ff7e2ea24a9, read/write=1, r/w location=0x0). Offset-info: 0x7ff7e35ad379
Ross
PostPosted: Sat Apr 27, 2019 11:09 am
BETA030 is available. I'm running a duration test now to try to catch that crash.... :(
PostPosted: Sat Apr 27, 2019 3:44 pm
when I switch from the old agc mode to the new agc
windows 7 64 bit
standalone stereo tool beta 30
PostPosted: Sun Apr 28, 2019 11:47 am
I've modified the preset and it now occurs far more often than before. After adding a lot of logging I think I may have found the cause now... running a new duration test to verify that it doesn't happen anymore.
PostPosted: Sun Apr 28, 2019 12:09 pm
windows 7 64 bit
Thanks for reporting it! Found & solved.
PostPosted: Sun Apr 28, 2019 4:05 pm
New build with both issues fixed is running....
