Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 155 posts ]  Go to page Previous 15 6 7 8 916 Next
PostPosted: Wed Aug 29, 2018 11:46 am
Stereo Tool 9.03 BETA012
Windows stand alone: https://www.stereotool.com/download/ste ... 03-012.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-012.exe
VST: http://www.stereotool.com/download/vst_ ... 03-012.dll
VST: https://www.stereotool.com/download/vst ... 03-012.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-012.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-012.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-012.exe
Windows libsndfile-1.dll (needed for MicroMPX decoder and command line version, place in same directory): MicroMPX command line enc/dec: https://www.stereotool.com/download/libsndfile-1.dll
New vs old Stokkemask measurement numbers, relative to 48 kHz no stokkemask, for audio with quite extreme stereo. Numbers are L-R loudness, L loudness
Freq     old/new          L-R    L
48   kHz no  Stokkemask:  0.00,  0.00 (reference)
48   kHz new Stokkemask: -0.62, -0.27 (0.46, 0.10 better than old!)
44.1 kHz new Stokkemask: -0.63, -0.22 (0.54, 0.11 better than old!)
40   kHz new Stokkemask: -0.82, -0.29 (0.65, 0.14 better than old!)
48   kHz old Stokkemask: -1.08, -0.37
44.1 kHz old Stokkemask: -1.17, -0.33
40   kHz old Stokkemask: -1.47, -0.43
  • New Stokkemask mode now works well in all Strictness settings above 7 (below 7 it's not very strict)
  • Stok: Post filter caused NANs
  • Stok: Move start point to later stage? (TUESDAY)
  • Cleanup code for VST3 David
  • Turn BIMP *OFF*
  • DrawWave draws outside of screen in FM analyzer (TUESDAY) - apparently ok
  • Include MicroMPX - for real now [22]
  • Hide Matrix Stereo for now
  • Stok: Add post filter
  • Stok: Legacy CPU load back to that of 9.02
  • API: Audio signal VU meter, info about whether stream is good NOW.
  • Started with matrix-based stereo widener; not happy yet.
  • Stokkemask NAN and other exceptions solved. (from previous beta)
  • Stokkemask threading issue solved. (from previous beta)
  • Stok: Remove overlap shortcut for stricter result (increases CPU).
  • Stok: Measure mask in every stage for stricter result (increases CPU).
  • Stok: Apply measured results in every stage for stricter result (increases CPU).
  • Stok: Replace L-R reduction in final stages by total volume reduction.
  • Stok: Figure out how to adjust shape at different sample rates -> Found correct Gaussian window sigma value instead, applied for both processing and display (which were set differently before!)
  • Stok: Replace "Looseness (sounds better)" by something that moves the mask up and down.
  • Stok: 1e stage only inner
  • Stok: More steps at end, needs to be both tighter and have less effect (is that last thing still needed???)
  • Stok: Try reducing the audio level in the final stage - lowering highs has proven useless at that point. --> SEEMS TO WORK, but only do this as the last stage!
  • MicroMPX SWEEP
  • Fixed a crash in the "Limit instead" code (Advanced Clipper).
  • Removed (moved to Extreme Tweaker for possible future testing) some Stokkemask settings that had a bad effect on compliance. Good settings are 50% / 30% / 40 dB (without the 40 dB it should be fne too, but there's a bigger chance at overshoots at the bottom of the mask. 100% for the first value increases overshoots!!!!! 39 and 38 should be safe as well - but I haven't had time to measure those separately anymore. Anyway in the older versions this value was set to 0....... Setting it higher may cause an audio quality reduction.
  • Crash fixed
  • Stokkemask: Try I/Q Clipper mode, highs are coming out slightly too loud, due to LPF? Might be good enough... -> Idea doesn't work
  • Stokkemask: We don't care about CPU load, try adding more stages -> No effect
  • Stokkemask: Default back to 50% for safety - that way we don't have to worry about breaking older versions. And we still get 90% of the improvement that way.
  • More experimental stokkemask settings added.
  • Stokkemask: Improved further (looks about equally strict, but I can squeeze over 1 dB more anti-phase content through than with 9.02). NOTE: SETTINGS ARE DEFAULTING TO 9.02 BEHAVIOR BECAUSE I DON'T KNOW YET IF THE SIGNAL IS EQUALLY STRICT, AND I DON'T WANT SOMEONE TO GET FINED FOR HAVING STOKKEMASK OVERSHOOTS. To get the new behavior, set "New looseness 1" higher (50% should definitely be safe, I'm not sure about 100%), "New looseness 2" to 30%, and "Side level" to 40.
  • Improved Stokkemask - output is stricter (closer to the mask), so it has less impact on stereo separation. (*)
  • Memory usage reduced by about 12 MB
    PLANNED:
  • Sneak peek - PHOTO
  • Stok: Lower samplerates look less good (and that makes no sense test without LOWER) -> 44.1 is ok now (-0.01 dB), 40 kHz is clearly lower (-0.20 dB), still way better than before (it was more than -0.40 dB in 9.02).
  • Add MicroMPX plugin licensing [22]
  • Fix Pi build (Stokkemask NEON code)
  • Update LogInOut code
  • Add MicroMPX decoder abonneer-IP Done but might not work - wait for Mathijs
  • Update Paul Thompson and Bojcha presets and Dutch Moose
  • Coins
  • The BIMP BUSY, done?
  • The BIMP on LQLL
  • Allow lower latency (6 ms, 9 ms) (it's just a setting, but show a warning if Quality it not set to 150%)
  • Crackle in 2nd PDF track
  • SST/uMPX interface BUSY
  • Improve clipper sound 1-6 kHz area
  • Video
  • Add Kantar support BUSY
  • RDS urgent issue
  • Cntrct IN
  • Test preset that causes buffer to run empty - why? --> Settings issue, maybe add a popup for this situation (buffer is slowly filling up or running empty)...
  • RDS: Support for AF method B
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
  • uMPX decoder: Add multicast subscribe
PostPosted: Wed Aug 29, 2018 3:45 pm
Hello, Hans,
I accidentally tried password management, and I noticed a bug in the windows layout that becomes completely messy, my resolution is 1920x1024 on a 22 inch screen. Linked images
PostPosted: Wed Aug 29, 2018 3:48 pm
Oops ! how to get smaller images in the forum :lol:
PostPosted: Wed Aug 29, 2018 4:19 pm
Ah, I need to hide those pages if you're logged out - I added them after adding password protection.... :(
PostPosted: Wed Aug 29, 2018 4:40 pm
If you restrict the use of the software by a password, only the login should appear at the top, of course the visual indications below for operation are displayed normally, this is my opinion
PostPosted: Thu Aug 30, 2018 9:57 pm
just installed 9.02 (upgrade from 8.54) on my Ubuntu 16.04 system (64 bit). I already mentioned the problem that the GUI does not always pops up when you start steretool on my system viewtopic.php?f=2&t=24054. It actually more often does not pop up then it does. The stereotool is running however, it is just the GUI that is not visible. After killing the process once or more and restarting it, it does pop up. Are you planning to have a look at this or are other Linux systems worth to give a try? I can do that if you prefer to.
Maybe someone else who is running ST on a Linux system? What OS do you use?
For now, great update! Bastardizer also sounds awesome 8-) . Keep up the good work!
PostPosted: Thu Aug 30, 2018 11:21 pm
Stereo Tool 9.03 BETA013
Windows stand alone: https://www.stereotool.com/download/ste ... 03-013.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-013.exe
VST: http://www.stereotool.com/download/vst_ ... 03-013.dll
VST: https://www.stereotool.com/download/vst ... 03-013.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-013.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-013.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-013.exe
Freq     old/new          L-R    L
  • Turn BIMP *OFF*
  • MicroMPX SWEEP
  • Crash fixed
    PLANNED:
  • Crackle in 2nd PDF track -> Improved
  • License The BIMP
  • SST ID's
  • Test The BIMP
  • Test MicroMPX with Stokkemask
  • PRESET
  • Fri: SST/uMPX interface BUSY
  • Video
  • Coins
  • The BIMP on LQLL
  • Lower latency quality warning
  • RDS urgent issue
  • Cntrct IN
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
PostPosted: Fri Aug 31, 2018 10:15 am
It seems to be a linux issue, since we've seen the same thing happening to other programs as well. It's certainly planned to have a look at this to find a workaround, though we're not sure when. Probably after IBC, anyway. Too busy already ;)
PostPosted: Fri Aug 31, 2018 4:42 pm
Its not called like "matrix" in Orban :).You can do when you set the AGC into Sum/Diff.
Also the Ariane Sequel works in "matrix" leveling what whil enchance your stereo.
For now in ST it have bad effects its "jumps and pumping" also fase problems when you set Difference mode and monitoring whith Correlation meter/Vectorscope
I'm doing tests on my Optimod this afternoon. I confirm that the option is called "AGC Matrix" on the Optimods. Then, you have to choose "L/R" or "sum/dif".
PostPosted: Sun Sep 02, 2018 11:59 pm
Beta 9.03 0.13 doesn't display GUI on Windows (x32 version).
Is this a known problem? Just a white window.
