Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 289 posts ]  Go to page Previous 120 21 22 23 2429 Next
PostPosted: Sat Jul 14, 2018 11:11 am
OK running it like this: MicroMPX_BETA902-011 -c 8854
it gets to License request code stage then it crashes (what license lib are you using?, if running it with MicroMPX_BETA902-011 --license info I get a readme and Warenty it aphears it you are using open source libs in it, is this allowed?(what did you use beside portAudio?))
not sure what logging you added, because it does not make any sense to me :)
Ah. So it got beyond the point where it's calculating the license code. (I added all those "L1", "L2" etc. lines to see how far it would get). But, a few lines after that it should already print "Starting CLIENT" and it doesn't. I'll add.... more logging.....
PostPosted: Sat Jul 14, 2018 11:51 am
@veso266: Can you try this one? (Command line version only, I added more logging)
https://www.stereotool.com/download/Mic ... 02-011.exe
PostPosted: Sat Jul 14, 2018 1:46 pm
started it the same as before with MicroMPX -c 8854
This is MicroMPX 1.4.0b2.
Start with no options for usage info.
Start with --licenseinfo to read 3rd-party library licenses.
PortAudio V19.6.0-devel, revision 396fe4b6699ae929d3a685b3ef8a7e97396139a4
MicroMPX is a command line tool. You need to start it from the command line,
with arguments to control its behavior.
To make it listen to a specific port (for example 8854), use -c 8854.
If you only have 1 192 kHz capable sound card it will automatically use that.
Otherwise, use -a to set a sound card. Use -l for a list of sound cards.
So first:
micrompx -c 8854 -l
Then pick the right sound card and use something like:
micrompx -c 8854 -a 4
micrompx -c 8854 -a "Line 2"
You can either use a number or a unique part of the sound card name. Numbers
may change upon restarts,so it's best to use a name,except for initial testing.
If you use a bitrate other than 320 (the default), you have to tell the decoder
that! Use -b 384 to set it to 384 kbit/s, for example.
micrompx -c 8854 -a "Line 2" -b 384
Run MicroMPX with option -h (or --help) for a detailed list of options.
Press ENTER to exit... ^C
D:\Users\Mitja\MEGA\Dropbox\Ostalo Dropbox\FM oddajanje\Stereo Tool\Stereo Tool
9.00\MicroMPX\MicroMPX Command Line Decoer and Encoder>MicroMPX_BETA902-011MoreL
ogging -c 8854
L1
L2
2018-07-14 13:44:08.824     info: 44 Audio devices available. Scanning for outpu
t devices supporting 192kHz
2018-07-14 13:44:08.826     info: Output 13: Line 1 (Virtual Audio Cable) (Windo
ws WASAPI, exclusive: yes; 2 channels)
2018-07-14 13:44:08.852     info: Output 15: Speakers (Realtek High Definition A
udio) (Windows WASAPI, exclusive: yes; 2 channels)
2018-L6
07L3
-l1
1l2
4 13:44:08.859     info: Output 17: Line 4 (Virtual Audio Cable) (Windows WASAPI
2018-07-14 13:44:08.893     info: Output 24: Speakers (Realtek HD Audio output)
(Windows WDM-KS 8 channels)
2018-07-14 13:44:08.893     info: Output 27: SPDIF Out (Realtek HDA SPDIF Optica
l Out) (Windows WDM-KS 2 channels)
2018-07-14 13:44:08.893     info: Output 28: SPDIF Out (Realtek HDA SPDIF Out) (
2018-07-14 13:44:08.894     info: Output 31: Line Out (Virtual Cable 1) (Windows
 WDM-KS 8 channels)
2018-07-14 13:44:08.894     info: Output 33: Line Out (Virtual Cable 2) (Windows
 WDM-KS 8 channels)
2018-07-14 13:44:08.894     info: Output 35: Line Out (Virtual Cable 3) (Windows
 WDM-KS 8 channels)
2018-07-14 13:44:08.894     info: Output 37: Line Out (Virtual Cable 4) (Windows
 WDM-KS 8 channels)
2018-07-14 13:44:08.894     info: Output 39: Line Out (Breakaway Pipeline 1) (Wi
ndows WDM-KS 64 channels)
2018-07-14 13:44:08.894     info: Output 41: Line Out (Breakaway Pipeline 2) (Wi
2018-07-14 13:44:08.894     info: Output 43: Line Out (Breakaway Pipeline 3) (Wi
2018-07-14 13:44:08.894     info: 13 suitable sound cards found
2018-07-14 13:44:08.896 critical: You do not have a license for MicroMPX decoder
l4
l5
l7
l8
l9
1 1
2 0
3 1
5
6 0
7 0
8 0
9 -1
D 24
10 0
11
12
13 0
DL 12
14
15 0
16 0
17 0
18 33
19 0
21
22
23
12
13 1
24
25
9 0
D 29
10 0
11
12
13 0
DL 12
14
15 0
16 1
17 0
18 41
19 1
21
22
23
12
13 0
DL 12
14
15 0
16 2
17 0
18 41
19 2
21
22
23
12
13 0
DL 12
14
15 0
16 3
17 0
18 17
19 3
21
22
23
12
13 0
DL 12
14
15 0
16 4
17 0
18 17
19 4
21
22
23
12
13 1
24
25
26
27
28
29 5
l10 5
l11 4 5
l12 8
l13
l14 118
l15
l16
l17
L4
2018-07-14 13:44:09.331     info: License Request Code: 0dcd02c0fb364204071c9d0b
249f5777fec3ad8f331feeb87fe98ff0cdbd71e1c89305c42959a085fb871db69eda5583acb5bbd0
348bfa7b546666e0251d008736e66850242b42cac3a293893c1bda8399f652321482ea1e9a6ac190
361868c1f2ec1e5
still crashing at exacly the same spot and no logging afterwards
PostPosted: Sat Jul 14, 2018 4:48 pm
@veso266: Sorry, my bad :( wrong link, should have been 012:
https://www.stereotool.com/download/Mic ... 02-012.exe
PostPosted: Sat Jul 14, 2018 5:13 pm
9.00\MicroMPX\MicroMPX Command Line Decoer and Encoder>MicroMPX_BETA902-012MoreL
ogging -c 8858
L1
L2
2018-07-14 17:12:41.793     info: 44 Audio devices available. Scanning for outpu
2018-07-14 17:12:41.795     info: Output 13: Line 1 (Virtual Audio Cable) (Windo
M1
M2
L6
m1
L3
{l1}
l2
2018-07-14 17:12:41.821     info: Output 15: Speakers (Realtek High Definition A
2018-07-14 17:12:41.828     info: Output 17: Line 4 (Virtual Audio Cable) (Windo
2018-07-14 17:12:41.863     info: Output 24: Speakers (Realtek HD Audio output)
2018-07-14 17:12:41.863     info: Output 27: SPDIF Out (Realtek HDA SPDIF Optica
2018-07-14 17:12:41.863     info: Output 28: SPDIF Out (Realtek HDA SPDIF Out) (
2018-07-14 17:12:41.863     info: Output 31: Line Out (Virtual Cable 1) (Windows
 WDM-KS 8 channels)
2018-07-14 17:12:41.863     info: Output 33: Line Out (Virtual Cable 2) (Windows
 WDM-KS 8 channels)
2018-07-14 17:12:41.863     info: Output 35: Line Out (Virtual Cable 3) (Windows
 WDM-KS 8 channels)
2018-07-14 17:12:41.863     info: Output 37: Line Out (Virtual Cable 4) (Windows
 WDM-KS 8 channels)
2018-07-14 17:12:41.863     info: Output 39: Line Out (Breakaway Pipeline 1) (Wi
2018-07-14 17:12:41.863     info: Output 41: Line Out (Breakaway Pipeline 2) (Wi
2018-07-14 17:12:41.863     info: Output 43: Line Out (Breakaway Pipeline 3) (Wi
2018-07-14 17:12:41.863     info: 13 suitable sound cards found
2018-07-14 17:12:41.867 critical: You do not have a license for MicroMPX decoder
l4
l5
l7
l8
l9
1 1
2 0
3 1
5
6 0
7 0
8 0
9 -1
D 24
10 0
11
12
13 0
DL 12
14
15 0
16 0
17 0
18 33
19 0
21
22
23
12
13 1
24
25
9 0
D 29
10 0
11
12
13 0
DL 12
14
15 0
16 1
17 0
18 41
19 1
21
22
23
12
13 0
DL 12
14
15 0
16 2
17 0
18 41
19 2
21
22
23
12
13 0
DL 12
14
15 0
16 3
17 0
18 17
19 3
21
22
23
12
13 0
DL 12
14
15 0
16 4
17 0
18 17
19 4
21
22
23
12
13 1
24
25
26
27
28
29 5
l10 5
l11 4 5
l12 8
l13
l14 118
l15
l16
l17
L4
m2
m3
2018-07-14 17:12:42.305     info: License Request Code: df900fc2503abd956d7e6f2d
7455af352b5df22b1ad19dd3da936b4f9eec6f196324eba19a1ed3cbba2a3ecf249d808cf8346b38
a3c31c0c28ac1a29cacf73ddfe5f153077d57549c056b8b85a59ef1e749f82944852461115694b1d
dfb334ee2579c4c
PostPosted: Sat Jul 14, 2018 9:00 pm
m2
m3
dfb334ee2579c4c
[/code]
Great! I found it! Turns out (this is a very scary one) that the logging code can't handle strings that are more than 255 characters long. Your request code is longer than normal, which causes it to crash.
PostPosted: Sat Jul 14, 2018 9:24 pm
m2
m3
dfb334ee2579c4c
[/code]
so why do we need this request code? how it is being generated?
PostPosted: Sat Jul 14, 2018 10:26 pm
m2
m3
dfb334ee2579c4c
[/code]
You need it to buy a license. Anyway, we'll fix this, should be simple enough now we know what's wrong.
PostPosted: Sun Jul 15, 2018 2:11 pm
Hans,
This is from my Windows 7 x86 machine when I try to install:
Faulting module name: MicroMPX_Decoder_BETA902-011.exe, version: 0.0.0.0, time stamp: 0x5b48cac5
Exception code: 0xc0000409
Fault offset: 0x000ed372
Faulting process id: 0x8b0
Faulting application start time: 0x01d41c32f711a199
Faulting application path: <Path> MicroMPX_Decoder_BETA902-011.exe
Faulting module path: <Path>\MicroMPX_Decoder_BETA902-011.exe
Report Id: 355bb6f0-8826-11e8-89fd-1c1b0d00c116
Works fine on my Win 10 64 bit machine.
C.
PostPosted: Sun Jul 15, 2018 2:26 pm
Thank you for the fix on the multiband clipper. I was able to set my clip levels with better ease. However, there's one thing that I noticed, and I'm not sure if this is by design or a slight oversight, but the Band Mix controls now seem to drive the clipper's input. Any band mix cut/boost will change the attentuation in the clippers respective to threshold. Previous to the addition of the clippers, the band mix controls only adjusted the output signal from the multiband compressor/limiter, basically to re-EQ the sound without adding more density. So from what I'm seeing now, the signal flow is; Limiter > Band Mix > Clipper. In the Quick Overview panel, it shows the flow as Limiter > Clipper > Band Mix. So I'm wondering, is the clipper supposed to be inserted after the band mix controls, or inserted before them? Probably before the band mix controls would be better?
