Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 759 posts ]  Go to page Previous 160 61 62 63 6476 Next
PostPosted: Wed May 16, 2018 12:06 pm
Stereo Tool 9.00 BETA068
NAN CHECKING IS ENABLED IN THIS VERSION
Windows stand alone: http://www.stereotool.com/download/ster ... 00-068.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-068.exe
VST: http://www.stereotool.com/download/vst_ ... 00-068.dll
- Added new (extra) simple bass clipper
- LQLL: Allow 3 threads instead of 2 (needed for HQ mode on slower systems)
- Sound cards: Add left/right channel swap
- Check clean_NAN -> Fixed, array in Delossifier wasn't initialized to 0, caused weird sound when changing Quality > 100% and (incorrectly) reported NAN error.
- Added MagicRDS AF method A (not tested!)
- Service code didn't print anything to screen due to (probably) Visual Studio .h file changes, solved.
- GUI: If the window is too small (which shouldn't be possible to achieve manually, but might still have happened if set to full screen mode), instead of not drawing, we now just draw in part outside of the visible area.
- GUI: Redraw when warning disappears automatically, also fixes other switches between modes
- GUI: Rename and deprecate Low CPU settings -> Inverted and named to "Heavy CPU (old), under "Compatibility" header.
- Installer: Add shortcuts for run as a service install/uninstall (Still have to do that for the 64 bit version!)
- Linux: 64 bit ARM ALSA build has Jack dependency - removed.
- Check if MagicRDS ASCII mode still works (report received that it's broken) => Works flawless here... Must be a wrong setting.
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha) - Should be solved by new bass clipper?
About the new bass clipper:
Main goal: Warmer mid-bass
In the past, people have complained about bass in Stereo Tool. Different people described completely different issues with it, which made it very hard to figure out what was wrong. With the new compressor mode, that lets far more transients through (including bass transients), the problem was getting worse, and as it turns out, deep bass was suffocating the mid bass. It took until now - and input from 4 different people - for me to figure out 1. what people were hearing and 2. what the solution was.
The key info that lead to this breakthrough was coming from Wes Keene, who reported that the Stereo Tool clipper after another processor does sound warm - warmth was only missing if it was used with Stereo Tool. And in those other processors he had bypassed the finalc clipper - but not the bass clipper. It was the combination of output from Stereo Tool and the Stereo Tool clipper that caused a lack of warmth.
Long ago, I made some (I thought) very smart bass clipper design that would protect higher frequencies against IMD, moreso from deep bass than from less deep bass. When I tried my trick out I expected it to sound bad - but I never heard any issue with it. That, as it turns out, was not really true.... now that I'm hearing the difference it suddenly sounds much better with this new fix.
So, what I did: I added another bass clipper, but a very simple, traditional one. The same type that all the boxes (even analog boxes) used. No smart stuff to avoid harmonics etc, just a stupid, simple bass clipper with a few modes (hard / soft / ultrasoft). If you use that bass clipper BEFORE the existing clipper, it protects the existing clipper from killing mid-bass frequencies if there's a lot of deep bass present, and the new bass clipper adds harmonics that give the sound more warmth and power. On top of these things, there is actually less IMD in the higher frequencies as well now!
This thing isn't completely finished yet, but it should be usable. Most importantly, I need to make it adjust its threshold to what the existing clipper is doing after it. For now, you'll have to do that manually. Also, the default settings may be way off - I have never even noticed that this mid-bass stuff was missing, so I'm definitely not yet an expert in setting this thing up. So I'll wait for feedback from others for that.
OLDER CHANGES:
- Natural Dynamics was broken in the last beta's. Now again same as in 8.54
- Show better license warning (maybe separate icon per used feature?)
- Added sound card input left/right/stereo selection (specific customer request).
- Fixed (enabled) highpass filter pre-ringing protection.
- We should probably put a warning in the next version if the CPU load is high. Done, but window doesn't nicely disappear (others as well probably)
- Start of song Auto EQ/Bass EQ was too soft: Sudden Jump Protection now only acts when a band is being boosted (that wasn't the case before); effect at beginning is nearly completely gone and overall AutoEQ/BassEQ SJP does far less than before, but is not less effective!
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Fix Matt's GUI crash at a specific size
- FM Analyser pilot tilt problem fixed
- AGC PEQ live updates (when editing) didn't work
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- Weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files - was ignoring size of commands for other receivers
- Fixed preset load error (060)
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Latest beta doesn't run on XP SP 2 (GetLogicalProcessorInfo can't be located in KERNEL32.dll). Question posted. => Too hard to figure out where it's coming from (and that wouldn't even necessarily mean being able to fix it).... I guess almost nobody will still be using XP SP2 anyway...
- Quality > 100% Bypass switching causes buffer filling to move -> Tested, not true
- SJP in AGC reported to be broken -> Seems fine
- ThimeoKoekError not initialized in uMPX in SST. (ptke = NULL, initializer isn't executed)
- Start of song AGC etc behavior. Fixed starting point, for AGC
- Remove Hans/Matt mode from Bass EQ or give local names if there's a reason to keep both.
- Bass clipper: Added "Reduce valleys" mode that reduces overreaction (keeps more deep bass and causes less harmonics)
- Bass clipper should do something with clipper drive.
- Rivendell plugin build. Mail sent.
- DJB plugin build. Mail sent.
- Add AM presets
- Add new presets
- Array met frequenties versus levels (dus de uitkomst van Fourier) resultaten naar buiten brengen
- Move bass clipper to a logical spot.
- Combine bass effects in GUI
- AVG
- NAS
- MicroMPX NIC selection broken in SST web interface - Koek
- Add MME warning
- Swap Bass EQ / True Bass when both set to between MB's.
- SST: Show warnings
- Website rename Products to Buy
- Display settings (Paul T)
- Muziek uploaden
- Use top part for extra displays (declipper, numbers for MPX level etc)
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Wed May 16, 2018 4:33 pm
Hans new simple bass clipper...
Interesting because Bob Orban put on 8500 a similar type of bass clipper, but he positioned at the crossovers of band 1 and 2... before compressing / limiting... and it caused a big difference at overall audio. OFC added some phase rotations, but the overall result was very good indeed...
"A clipper, embedded in the crossover, protects bands 1 and 2 from transient overshoot.
This clipper has a shape control, allowing you to vary the “knee” of its input/
output transfer curve from hard (0) to soft (10)..."
PostPosted: Thu May 17, 2018 12:09 am
HI Hans
i,m testing the new bass clipper ...very impresive ...and effecting in AM modulation
thanks :D :D :D :D
PostPosted: Fri May 18, 2018 7:13 pm
Do we have an ETA for 8.55?yes 9.this has been a long beta
PostPosted: Fri May 18, 2018 8:05 pm
The betas are 9.00 betaxxx so it looks like the production release will be 9.00
PostPosted: Sat May 19, 2018 10:47 am
The todo list (before the empty line) is getting smaller - so I'm hoping to have something around a week from now. Yes this one has taken really really long..... But the improvements are also really big!
PostPosted: Sat May 19, 2018 10:52 am
Stereo Tool 9.00 BETA074
NAN CHECKING IS ENABLED IN THIS VERSION -> If nobody is getting NAN's anymore I will turn it off for the next build
Windows stand alone: http://www.stereotool.com/download/ster ... 00-074.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-074.exe
VST: http://www.stereotool.com/download/vst_ ... 00-074.dll
- Add a pre-bass clipper without configuration in the main clipper, to avoid suffocating mid-bass
- Bass clipper should do something with clipper drive. -> Not anymore if pre-bass clipper works
- NAN reported in basstardizer - MAYBE fixed, waiting for feedback
- Find optimal # steps for pre-bass clipper - 2 if Fisherman's Friend mode works well.
- Fix 80 Hz bump in pre-bass clipper
- Optimize pre-bass clipper - Not very interesting, maybe later
OLDER CHANGES:
- Start of song AGC etc behavior. Added starting point setting for AGC
- Renamed Hans/Matt mode to a more logical name in Bass EQ; changed display of number of bands to match what makes sense to users.
- Quality > 100% Bypass switching causes buffer filling to move -> Tested, not (or no longer?) true
- SST: ThimeoKoekError was not initialized in SST. (ptke = NULL, initializer isn't executed), so uMPX encode errors were not shown
- New skin
- RDS: Add PTYN
- VST version no 4K
- Self test crashes
- Add AM presets
- Add new presets
- AVG
- NAS
- Add MME warning
- Muziek uploaden
- Kant
- Classical preset
- Test NanoPi
- Check out Butt
- WatchCat website
- Triple stuff
- One bass page
- Talk to chip
- 2 jaar
- Fardau
NEW BASS CLIPPER:
NOTE: Bass EQ
PostPosted: Sat May 19, 2018 2:06 pm
Stereo Tool 9.00 BETA071
Not working for Legacy AGC.
PostPosted: Sat May 19, 2018 3:30 pm
Ah, I forgot to hide it in legacy mode.
PostPosted: Sun May 20, 2018 2:55 pm
Be worth the wait though.lookung forward to it cheers!
