Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 759 posts ]  Go to page Previous 149 50 51 52 5376 Next
PostPosted: Fri Apr 06, 2018 8:01 pm
"I get an exception in beta 060 when i load the new presets from Wes and Bojcha."
Where are these new presets from Wes and and Bojcha?
I'm seeing them in the FM 75us section of the preloaded presets. They probably exist other places, too.
PostPosted: Fri Apr 06, 2018 8:47 pm
DynaRider_NEW_v0.00.50-HD_ST_9.00b060.sts [119.03 KiB]
Downloaded 145 times
DynaRider_NEW_v0.00.42-FM_50us_ST_8.55b059.sts [119.06 KiB]
Downloaded 92 times
FM Version need to catch HD version.
PostPosted: Fri Apr 06, 2018 9:13 pm
Thanks!
PostPosted: Sat Apr 07, 2018 2:24 am
Hans, you might want to check my previous post regarding the "Legacy Mode" bug for the VST version of Stereo Tool. It affects both 32 and 64 bit.
That is, "Legacy Mode" is enabled by default unless the user switches to an operating mode higher than "Basic" and changes it, or selects "Reset" -> "All Settings (Factory Reset)" every time Stereo Tool is run, unless the user is using a DAW or host that retains previous settings.
The modules this affects include AutoEQ, Low Level Boost, and AGC.
There are ALSO bugs with Multiband and Multiband 2 as well! They default to "Legacy Mode" for the "Limiters" section, regardless if a factory reset is performed. That may be intentional there, but...
ALSO, if the user performs a factory reset, they lose the ability to select "Digital" or "Analog" for the compressor type for Multiband and Singleband; they will be stuck in Analog mode. (Multiband 2 is always Analog.)
In fact, when loading Stereo Tool VST for the first time (i.e., no .ini file), the user is also unable to select "Digital" or "Analog" for the compressor type for Multiband and Singleband. They will have to do "All Settings (Factory Reset)", then re-load Stereo Tool VST. If using a DAW which retains settings, they will have to clear this before reloading the Stereo Tool VST. And of course, re-loading Stereo Tool without doing "All Settings (Factory Reset)" will mean that "Legacy Mode" is enabled by default for AutoEQ, Low Level Boost, and AGC.
What a mess! :o Hope you can fix... and hope there aren't other things affected by this. :?
I did check and this is all still happening in the latest beta at the time of this post (v9.0 Beta 60).
PostPosted: Sat Apr 07, 2018 8:11 am
OK, I just checked EVERY setting. To make things clear (for reproducing):
- Start clean (i.e., no .ini file in C:\Users\[USERID]\ directory)
- Load Stereo Tool VST into DAW which does NOT REMEMBER SETTINGS (i.e., Wavosaur)
- Enter License
- Select "Reset" -> "All Settings (Factory Reset)"
- Exit and restart DAW. Reload Stereo Tool VST. Set operating mode to "Extreme Tweaker". Set your choice of skin or leave default.
Now, there are differences in default settings, depending on if you AGAIN select "Reset" -> "All Settings (Factory Reset)":
  • Phase rotation: If "Reset" -> "All Settings (Factory Reset)" is performed, "At start of processing" button disappears. Otherwise it will be visible.
  • Auto EQ: If "Reset" -> "All Settings (Factory Reset)" is performed, "Legacy mode" will not be selected. Otherwise it will be selected.
  • Low Level Boost: If "Reset" -> "All Settings (Factory Reset)" is performed, "Legacy mode" will not be selected. Otherwise it will be selected.
  • AGC: If "Reset" -> "All Settings (Factory Reset)" is performed, "AGC type" drop down will NOT be available, and will be permanently set to the "Current AGC" setting. "Legacy mode" will not be selected. Otherwise, "AGC type" drop down will be available, preset to "Legacy AGC," and the "Legacy mode" setting will be enabled. Also, until the user drags a window over the drop box, or toggles the skin, there are drawing errors:
  • Basstadizer: If "Reset" -> "All Settings (Factory Reset)" is performed, "Use Legacy mode (Bass Boost)" will not be selected, and Basstadizer defaults will be selected (although in the GUI, the column heading is spelled "Bassta r dizer"). Otherwise, "Use Legacy mode (Bass Boost)" will be selected, with Bass Boost defaults selected.
  • Multiband: If "Reset" -> "All Settings (Factory Reset)" is performed, "Compressor type" drop down will NOT be available, and will be permanently set to the "Analog" setting. Otherwise, "Compressor type" drop down will be available, preset to the "Digital" setting and defaults.
    Note: On the first Multiband's "Limiters" subsection (for analog mode), "Limit before compress" and "Legacy" mode all have check mark toggles enabled by default whether "All Settings (Factory Reset)" is performed or not, but they are grey, which seems to suggest they are not used, as are the "Limit speed" sliders. This isn't the case on the "Limiters" section for "Multiband 2".
  • Singleband: If "Reset" -> "All Settings (Factory Reset)" is performed, "Compressor type" drop down will NOT be available, and will be permanently set to the "Analog" setting. Otherwise, "Compressor type" drop down will be available, preset to the "Digital" setting and defaults.
Hope this info is helpful!
I think I found the cause of the crash when loading presets, while sitting in the Minneapolis airport. Internet connection was pretty bad and my pc decided to perform a Windows update :( so I don't know yet if I fixed it.
PostPosted: Sat Apr 07, 2018 8:55 am
- Enter License
This is *partially* the intended behavior.
For many of these settings, the new (better) option replaces the old one (that's still available for compatibility reasons). Once you select the new setting, the selection itself disappears. If you want to see them anyway, enable "Show deprecated settings" (under Configration).
What's wrong is this: The default preset after loading is very old, and because of that, uses many of the old (legacy/digital mode etc) settings. I guess I need to relace it. That would remove this difference.
PostPosted: Sat Apr 07, 2018 5:01 pm
Stereo Tool 9.00 BETA061
NAN LOGGING REMOVED!
Windows stand alone: http://www.stereotool.com/download/ster ... 00-061.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-061.exe
VST: http://www.stereotool.com/download/vst_ ... 00-061.dll
VST: http://www.stereotool.com/download/vst_ ... 00-061.dll STILL BUILDING
- Fixed preset load error (060)
OLDER CHANGES:
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- Fix Matt's GUI crash
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- SST & 9sg weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files
- Analyser pilot tilt
- AGC PEQ doesn't do live updates
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Muziek uploaden
- Bonus
- Bank dl
- RW
- Rivendell plugin build
- DJB plugin build
- NAS
- Start of song AGC etc behavior. Fixed starting point, for AGC, maybe also for Auto EQ/Bass EQ
- Quality > 100% extreme CPU warning and recovery
- Quality > 100% Bypass switching causes buffer filling to move
- Add AM presets
- Add new presets
- SST: We should probably put a warning in the next version if the CPU load is high.
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha)
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Sat Apr 07, 2018 7:26 pm
hassle-free overhere ...
https://dreamstream.mobi
Currently live processing ST 9.02 , testing upgrade to auto equalizer offline using slightly modified 3 FM settings Bojcha
PostPosted: Sat Apr 07, 2018 9:48 pm
Bojcha is the HD preset ok for use on web radio?
