Stereo Tool 8.55 BETA
049
Windows stand alone:
http://www.stereotool.com/download/ster ... 55-049.exe
Winamp DSP:
http://www.stereotool.com/download/dsp_ ... 55-049.exe
VST:
http://www.stereotool.com/download/vst_ ... 55-049.dll
VST:
OLDER CHANGES:
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Added "Relative release threshold" slider; removed Symmetry slider. For all dynamics processing things (so LLB, AGC, Auto EQ, compressors). Not 100% sure yet if this is a good idea for Auto EQ. See text below
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Make OUTPUT_BB work with Basstardizer
- Does ACR DIFF mode cause NAN's?
- Check reported silence error
- near05 VST crash
- Classical preset
- Aanvraag uren
- Add AM presets
- Flip switch for latency?
- Test NanoPi
- MB2 band coupling bug: something is wrong, check better-fg-plus.sts ->
Seems ok now. Weird.
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
Important: The CPU load is really high right now. I will optimize it later.
Also important: You can't just enable this new mode and expect everything to be fine without changing the settings. For small level differences there won't be a difference, but there will be for big differences. You'll definitely notice the slower attack on big level jumps.
