Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
 Post subject: Stereo Tool 8.52
PostPosted: Mon Oct 09, 2017 12:03 am
New Release v8.52 - 2017/10/05
:!: WatchCat: Added Mac OS X version.
:!: Stand alone version: Moved memory allocations to before actual audio is running to avoid hiccups after starting Stereo Tool.
Sound card buffer could be filled too much until you did a RESTART SOUND CARDS.
:!: Made external RDS follower PLL much slower to avoid bad pilot.
:!: Web interface: Added way to use it remotely without knowing the session ID (use ID -1).
:!: Auto EQ: Updated default settings.
:!: Omnia.9/9sg: AutoPilot smooth transition between pilot and no pilot.
:!: Omnia.9/9sg: Made some build settings changes to avoid #define issues between projects.
:!: MicroMPX: Added logging for the Omnia.9.
:!: MicroMPX: Added version number to the external library API.
:!: MicroMPX: Added support for AutoPilot.
:!: MicroMPX: Many other small (signal) improvements.
:!: Bug fix: Declipper didn't work properly at 192 kHz with non-phase linear HPF enabled.
:!: Updated German translation and presets.
https://www.stereotool.com/download/
 Post subject: Re: Stereo Tool 8.52
PostPosted: Mon Oct 09, 2017 1:18 am
Issue launching WatchCat on OSX 10.12.5. Works greate on Win10.
(I tried attaching the error in a txt file but extention not allowed) :)
Anyhow, take care
MrDonT
___________________________________________
Process: ThimeoWatchCat [62114]
Path: /Applications/ThimeoWatchCat.app/Contents/MacOS/ThimeoWatchCat
Identifier: com.yourcompany.ThimeoWatchCat
Version: 0
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: ThimeoWatchCat [62114]
User ID: 501
Date/Time: 2017-10-09 01:08:27.562 +0200
OS Version: Mac OS X 10.12.5 (16F73)
Report Version: 12
Anonymous UUID: 615A1EAD-AC22-9BED-023A-1F21710EE3A2
Time Awake Since Boot: 1500000 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @executable_path/../Frameworks/libsndfile.1.dylib
Referenced from: /Applications/ThimeoWatchCat.app/Contents/MacOS/ThimeoWatchCat
Reason: image not found
Binary Images:
0x10489e000 - 0x10498ffff +com.yourcompany.ThimeoWatchCat (0) <26255246-FEEF-3EED-92D3-B5753571104B> /Applications/ThimeoWatchCat.app/Contents/MacOS/ThimeoWatchCat
0x10e1e8000 - 0x10e225dc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
PostPosted: Mon Oct 09, 2017 3:11 am
What is AutoPilot?
PostPosted: Mon Oct 09, 2017 10:27 am
Hans, thanks again!
On todo list linux Jack version;
Still Jack line-out and FM-out are interchanged (verwisseld)
PostPosted: Mon Oct 09, 2017 1:05 pm
Hm, weird. That OS X library IS included in the .dmg file, maybe not at the right location - but it worked here. Will look into that tomorrow.
PostPosted: Mon Oct 09, 2017 4:11 pm
What is AutoPilot?
It's not in Stereo Tool, it's Omnia.9/9sg/11(?) specific feature although it has been requested to be revealed in Stereo Tool too.
It's a function that switches off pilot tone whenever mono audio is driven. That way noise is considerably lower since receivers are not decoding stereo. Problem is, when pilot tone is put back on when stereo audio is again present, receivers may or may not enable stereo decoder after the break.
PostPosted: Tue Oct 10, 2017 8:47 am
What is AutoPilot?
Thanks for the good explanation. Sounds not bad. But isn`t this a problem of the receiver?
I test this with all my receivers and they all behave the same -> If pilot is on, stereo is on, if not - then not.
I guess some new receivers may have this problem. And the solve is to re-tune the station again, right ?
PostPosted: Tue Oct 10, 2017 2:43 pm
Ok one library was missing. Could you try again? I've just updated the .dmg file (you might need to refresh your cache).
PostPosted: Tue Oct 10, 2017 7:45 pm
Edit 1:
Made me a fix;
1. Copied libsndfile.dylib from /Contents/Frameworks/ to /usr/local/lib/ and renamed it libsndfile.2.dylib.
Then it yelled for "libvorbis.0.dylib" witch is in the correct place.
2. Copied libvorbis.0.dylib to /usr/local/lib/.
Tried booting the Cat again and cabam di dam, it works nicely :)
Atleast it started, going to have to play with it to see if it works this way hehe
Edit 2: It purrs along :) Works perfectly.
Thx for the greate work, guys.
Sorry Hans, still no go.
The new version of ThimeoWatchCat dated at 14:10 PM today still misses the same lib. The libsndfile.dylib is there but not libsndfile.1.dylib that the program wants.
Dyld Error Message:
PostPosted: Tue Oct 10, 2017 10:22 pm
Oops! Tomorrow...
