Post new topic  Reply to topic  [ 12 posts ]  Go to page Previous 1 2
 Post subject: Re: Stereo Tool 8.51
PostPosted: Fri Sep 29, 2017 6:52 pm
And why is cataclysm ? Cause it dont have compression ratio 300000:1 and cosmic speeds ? ?
PostPosted: Sat Sep 30, 2017 12:14 am
Do i really need to explain? Every bass kick makes holes in almost every sound.
Hans told you, and i will tel you bit more...
When you use 0 bass peek (does not mean that settings is 0, look at scope real bass peek) you are risking to have many bad things, like holes, distortions (especially wih asymetric sounds), idm..etc.
So never use bass peek level more then -2 - -1dB, and then you will be on good way to have "safe" loudness. Yes, it will kill your bass/kick/punch a bit, but that's it. It's all in compromisses. You just cannot have all. Balancing between is everrything.
Set only "clip deep bass bellow.." to 80% and already things are much better..
Trust me, Hans's bass part of clipper is not perfection, it even has a 'bug' - i think around 35-40Hz. So be careful.
Other aspects of preset are also bad to me. Highs amount first.. and for other i didnt go that deep.
