PostPosted: Wed May 31, 2017 5:03 pm
What happens if you put stereotool arm version on a snapdragon 835 arm COMPUTER ?
Using snapdragon arm cpu , stereotool could WORK WITH ALL FEATURES ENABLED.
HP, Lenovo and ASUS aim to release first Snapdragon 835 Windows 10 PCs
BUT , on what linux version? :D :D :D :D
http://www.linaro.org/downloads/#member-builds
and an old press release from qualcom
https://www.qualcomm.com/news/onq/2014/ ... processors
does anyone know if there is going to be any snapdragon 835 pc soon with lunux ?
windows 10 is on the way for snapdragon 835 ! check :
https://www.windowscentral.com/hp-lenov ... dows10-pcs
PostPosted: Thu Jun 01, 2017 6:36 pm
Ow!
CPU Clock Speed
Up to 2.45 GHz
CPU Cores
8x Qualcomm® Kryo™ 280 CPU
CPU Bit Architecture
64-bit
Yes this should easily do it.
