Post new topic  Reply to topic  [ 58 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Sat May 27, 2017 4:15 pm
I'm adding this to the 8.36 beta thread to help with the upcoming. I'm running into issues on Ubuntu 16.04 LTS and StereoTool 64 bit GUI (both the Jack and ALSA version).
The Jack version provides a segmentation fault right after launching and the ALSA version provides this:
Thimeo Stereo Tool 8.34 (for Linux with Jack) (C) Hans van Zutphen, 2001-2017
ALSA lib pcm_dsnoop.c:606:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:1029:(snd_pcm_dmix_open) unable to open slave
ALSA lib setup.c:548:(add_elem) Cannot obtain info for CTL elem (MIXER,'IEC958 Capture Switch',0,0,0): No such file or directory
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
Expression 'r' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2092
Expression 'PaAlsaStreamComponent_FinishConfigure( &self->capture, hwParamsCapture, inParams, self->primeBuffers, realSr, inputLatency )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2726
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2838
Expression 'PaAlsaStreamComponent_FinishConfigure( &self->playback, hwParamsPlayback, outParams, self->primeBuffers, realSr, outputLatency )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2733
Let me know if there are debugging flags that you'd like me to run to help troubleshoot.
Thanks.
PostPosted: Sat May 27, 2017 5:22 pm
looking forward to this release :D
PostPosted: Sat May 27, 2017 7:44 pm
Just curious: are in new beta new versions of Wes Keene presets as well?
PostPosted: Sat May 27, 2017 8:42 pm
No. The presets in this beta are identical to the 8.34 release.
PostPosted: Sat May 27, 2017 10:08 pm
Hans, while you're at it maybe you could also make the analog compressors reach the same target at the same speed for sine waves with same amplitude but varying frequency. Also in peak mode the shape shouldn't depend on the frequency.
PostPosted: Sun May 28, 2017 11:23 am
I think Multiband 2(if enabled) is before Multiband 1 . Am i right ?
PostPosted: Sun May 28, 2017 1:29 pm
NO.
PostPosted: Sun May 28, 2017 2:21 pm
Good look trying to get Hans attention to this.
Thanks.
PostPosted: Sun May 28, 2017 3:23 pm
Linux and Pi builds for 8.36-006. The Jack version should be ok again now.
LINUX 32:
Cmd: http://www.stereotool.com/download/ster ... ETA836-006
ALSA: http://www.stereotool.com/download/ster ... ETA836-006
Jack: http://www.stereotool.com/download/ster ... ETA836-006
LINUX 64:
PI:
PostPosted: Sun May 28, 2017 3:56 pm
Confirmed - the Jack version is working on Ubuntu 16.04 LTS 64 Bit.
