 Post subject: Stereo Tool 8.31
PostPosted: Wed Apr 19, 2017 6:28 pm
$ rm .stereo_tool.rc
$ stereo_tool_gui_64
Thimeo Stereo Tool 8.31 (for Linux with Jack) (C) Hans van Zutphen, 2001-2017
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867:(find_matching_chmap) Found no matching channel map
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
^C
 Post subject: Re: Stereo Tool 8.31
PostPosted: Wed Apr 19, 2017 9:06 pm
I appear to be unable to save settings in the Winamp Version of ST 8.31. Attempting to do so causes Winamp to lock up - Stereotool keeps playing but I have to force quit it.
Can anyone else confirm? Not sure when it last worked, it's been ages since I've saved settings :)
I just use ST Winamp to listen to music.
PostPosted: Wed Apr 19, 2017 10:08 pm
Just tried exporting all settings and it worked fine. What do you mean, locks up?
PostPosted: Wed Apr 19, 2017 10:29 pm
Just that - Winamp becomes unresponsive.
That said, I am using the Winamp Community Update Pack - so maybe this is the problem.
I'll test with "Pure" Winamp and see if the same happens.
PostPosted: Wed Apr 19, 2017 11:06 pm
Seems to work fine here at work, using the same Winamp Community Update Pack version.
Not sure what the problem is at home, but it's obviously my problem and not ST's. Apologies for the noise.
edit: I found the issue - one of the Winamp plugins I was using.
