Startup crash on Mac:
Process: stereo_tool [42254]
Path: /Applications/stereo_tool.app/Contents/MacOS/stereo_tool
Identifier: com.soundaudioprocessing.www
Version: 8.24 (???)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: stereo_tool [42254]
User ID: 501
Date/Time: 2017-02-21 10:33:36.540 +0100
OS Version: Mac OS X 10.12.3 (16D32)
Report Version: 12
Anonymous UUID: 18E97C39-AB03-63D0-D43D-1DDBA053335A
Time Awake Since Boot: 170000 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/lib/libportaudio.2.dylib
Referenced from: /Applications/stereo_tool.app/Contents/MacOS/stereo_tool
Reason: image not found
Binary Images:
0x1004b8000 - 0x1012d6fdf +com.soundaudioprocessing.www (8.24 - ???) <34665907-D62C-308D-A5E2-021BBF3E78B9> /Applications/stereo_tool.app/Contents/MacOS/stereo_tool
0x112d1b000 - 0x112d58267 dyld (421.2) <947FC440-80F9-32F7-A773-6FC418FE1AB7> /usr/lib/dyld
0x7fff9ea2d000 - 0x7fff9ea2dfff com.apple.ApplicationServices (48 - 48) <237200C2-28A6-3C19-B34B-53C953F8AE42> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff9fb6a000 - 0x7fff9fb6afff com.apple.Cocoa (6.11 - 22) <CF1AD0E9-2257-35FE-B719-760B58E405C9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fffa1b70000 - 0x7fffa1f17ff3 com.apple.Foundation (6.9 - 1349.25) <D820A498-2E62-367D-BC72-5845B14C06E3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffb4142000 - 0x7fffb4143ff3 libSystem.B.dylib (1238) <9CB018AF-54E9-300F-82BE-81FE553C9154> /usr/lib/libSystem.B.dylib
0x7fffb4e66000 - 0x7fffb523b127 libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
Model: Macmini6,2, BootROM MM61.0106.B0B, 4 processors, Intel Core i7, 2,3 GHz, 16 GB, SMC 2.8f1
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x0198, 0x393955353432382D3036332E4130304C4620
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x0198, 0x393955353432382D3036332E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x10E), Broadcom BCM43xx 1.0 (7.21.171.68.1a5)
Bluetooth: Version 5.0.3f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Samsung SSD 850 EVO 500GB, 500,11 GB
Serial ATA Device: APPLE HDD ST1000LM024, 1 TB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Hub
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: Rode Podcaster
Thunderbolt Bus: Mac mini, Apple Inc., 23.4
