Post new topic  Reply to topic  [ 54 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Mon Dec 12, 2016 2:34 pm
Ow. 8.14 is newer than the beta though. Did you do anything special when this happened?
It crashes here, but according to the error message there's a read of address 0. And this is a write... And ecx and eax should both have been 0. That's really odd... I really need more info! If it reproduces constantly on your end, please send me your (complete) settings (the .ini file).
EDIT: I just realized that I think I have seen this before, If I'm right, this is caused by a memory alignment that is reported in a strange way, What CPU do you have?
Note to self:
098DCEB2  addps       xmm1,xmm0
098DCEB5  rsqrtps     xmm7,xmm1
098DCEB8  movaps      xmm0,xmmword ptr ds:[9E16F50h]
098DCEBF  andps       xmm5,xmm1
098DCEC2  cmpleps     xmm0,xmm5
098DCEC6  andps       xmm0,xmm7
098DCEC9  mulps       xmm1,xmm0
098DCECC  mulps       xmm0,xmm1
098DCECF  movss       xmm5,dword ptr [edx+eax*8+28h]
098DCED5  movss       xmm6,dword ptr [edx+eax*8+3Ch]
098DCEDB  movss       xmm7,dword ptr [edx+eax*8+34h]
098DCEE1  subps       xmm0,xmmword ptr ds:[9E16F30h]
098DCEE8  mulps       xmm1,xmm0
098DCEEB  mulps       xmm1,xmmword ptr ds:[9E16F40h]
098DCEF2  mulps       xmm1,xmm2
098DCEF5  movaps      xmmword ptr [ecx+eax*4],xmm1  		********
098DCEF9  maxps       xmm3,xmm1
098DCEFC  movss       xmm1,dword ptr [edx+eax*8+38h]
098DCF02  movss       xmm0,dword ptr [edx+eax*8+20h]
098DCF08  unpcklps    xmm5,xmm1
098DCF0B  movss       xmm1,dword ptr [edx+eax*8+30h]
098DCF11  unpcklps    xmm0,xmm1
098DCF14  movss       xmm1,dword ptr [edx+eax*8+2Ch]
098DCF1A  unpcklps    xmm0,xmm5
098DCF1D  movss       xmm5,dword ptr [edx+eax*8+24h]
098DCF23  unpcklps    xmm1,xmm6
098DCF26  unpcklps    xmm5,xmm7
098DCF29  unpcklps    xmm5,xmm1
098DCF2C  mulps       xmm0,xmm0
098DCF2F  mulps       xmm5,xmm5
098DCF32  movaps      xmm6,xmmword ptr ds:[9E14E60h]
098DCF39  addps       xmm0,xmm5
098DCF3C  rsqrtps     xmm7,xmm0
PostPosted: Tue Dec 13, 2016 6:43 am
Hans,
The 8.14 DSP that I downloaded from the Download page is the one that gave the error. The latest one I downloaded from this topic 8.14 Beta 02 works fine.
All I did was start it as a DSP in an application to get the error.
The current Beta in this topic of the standalone is also 8.14 Beta 02 posted November 27th which I have been running as latest but your saying the Standalone in the Download area is latest?
Edit: My confusion as on this 64 bit machine I run 32 bit and 64 bit versions. Now have 8.14 64 bit exe dated 29th November.
C.
PostPosted: Tue Dec 13, 2016 9:55 am
The one in the download area is the latest. But.. there is only a 32 bit DSP plugin version so what do you mean you have the 64 bit?
And what CPU do you have?
PostPosted: Tue Dec 13, 2016 3:24 pm
Hans,
The versions I have are the Standalone 8.14 x64 which is the main one we use on our main PC and also on this machine (not on the main PC) the 8.14 x86 which will get overwritten by the next released beta.
The DSP version was the one I had the issue with as I downloaded it to demonstrate to someone. It has now been removed.
This machine in the Tech Lab and our main PC that runs ST for air are both i7 4790K, Windows 7 x64, 16G RAM. The main PC runs a Marian Trace Alpha and this one runs a Juli@ XTe.
C.
