 Post subject: CHR Radio Preset
PostPosted: Sat Sep 10, 2016 11:41 am
Hello, this is my version of the CHR Radio Preset, This is intended for music stations which genre is a Contemporary Hit Radio Format, this works well too on the other music and also works great if you just listen around, it has some punchy sound and good vocals too. I Am using all-analog Multiband, Compressor, Single Band and others. Please let me know how the preset sound.. thanks!!
File comment: Unzip the files then go :)
CHR Radio Presets.zip [230.26 KiB]
Downloaded 1778 times
 Post subject: Re: CHR Radio Preset
PostPosted: Sun Feb 26, 2017 2:37 am
Hello!! Just updated the CHR Radio Preset, Let me know how it sounds thanks!!
File comment: Extract and Use :)
ST8.23CHRPRESET.zip [120.24 KiB]
Downloaded 1067 times
PostPosted: Fri Mar 03, 2017 3:37 am
I just wanted to share presets CHR, more specifically the song Pop / Top40 Indonesia
to listen to the results in our radio streaming http://www.nagaswarafm.com or http://bogor.nagaswarafm.com:8088
thank you
CHR_Preset_Indonesian_Songs.rar [95.94 KiB]
Downloaded 499 times
PostPosted: Fri Mar 03, 2017 3:38 am
thank you
File comment: I just wanted to share presets CHR, more specifically the song Pop / Top40 Indonesia
thank you
Downloaded 566 times
