 Post subject: Warm Clarity preset
PostPosted: Sun Apr 10, 2016 11:59 am
I was inspired some time ago by what I think was the Pristine preset, in which all of the multiband attack/decay times were the same and have been playing around with this idea.
The result is 'Warm Clarity', the idea of which is to have a clear upper end, whilst adding lots of warmth. Some settings are unsurreptitiously borrowed from other presets.
Comments very welcome - I have been running this on an FM transmitter to test and it sounds good on the test receivers I have but I only have 4 or 5 receivers to try...!
Bob
WarmClarityv233.sts [88.16 KiB]
Downloaded 792 times
 Post subject: Re: Warm Clarity preset
PostPosted: Fri May 13, 2016 8:15 am
Made a few changes to clean up the bass which was a little woolly. It breaks from the 'all attack/decay' times the same concept but sounds nicer.
Also changed the name to 'Liquid Diamond'.
Working on a louder version that will be called 'Rough Diamond'!
Bob
Liquid Diamond 1.sts [88.03 KiB]
Downloaded 622 times
PostPosted: Sat Dec 03, 2016 6:26 pm
Much improved version XVII (yes, 17, and that's after I got bored adding letters of the alphabet so it's really version 43). Super punchy bass yet shiny tops with clear mids, or something like that. Give it a try!
Liquid Diamond XVII.sts [92.64 KiB]
Downloaded 650 times
