Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: 7wonders
PostPosted: Thu Jun 23, 2016 6:11 pm
@Bojcha,
Any updates planned to bring this fantastic preset up to 8.00 standards?
Thanks.
Three Decades of Country!
PostPosted: Thu Jun 23, 2016 10:22 pm
Slowly.. i am on something really different :)
In day or two i will post something.
beta testing:
here: http://85.25.73.243:10460
and
here:http://85.25.73.243:9840/
PostPosted: Fri Jun 24, 2016 6:05 pm
beta testing:
and
YAY!
PostPosted: Fri Aug 26, 2016 7:03 pm
@Bojcha: what is the AGC average level in this preset, I've usually read 18 dB or more, my library is normalized to 0 dB.
https://fmfeeling.com
PostPosted: Sat Aug 27, 2016 9:58 pm
That what you read on bar is "range" You can easily chage that with "post-amp" slider.
PostPosted: Sun Aug 28, 2016 6:15 pm
Yeah, I know that. I need to know what is the best average value for this preset, I've read around -18/24 dB. I think that is too high.
PostPosted: Mon Aug 29, 2016 1:55 am
beta testing:
and
One of the links is published the HiperFM, I know and I often hear, a Portuguese radio with great success among young people, the radio CHR, I loved having a similar sound in web radio but my lot to find a similar file can not.
PostPosted: Mon Nov 21, 2016 4:22 pm
Removing my post... I've made so many changes to this that I'm going to just post it in a separate post. Thanks!
PostPosted: Tue Nov 22, 2016 7:40 pm
Nice preset.. i just update the stream!
http://93.190.142.179:8066/listen.pls
Or www.radiowaubach.nl
Greets
Johnny.
PostPosted: Thu Nov 24, 2016 11:56 am
Good morning!
Love the sound of this preset! For offline processing and more dynamic headroom, I made a few changes for personal use. When the original and the result of this setting is volume-matched, there is a major difference. The original just sounds flat, and the stereo image is collapsed.
7wonders_v027_dynamic_offline_use.sts
Below are the list of changes made:
1. Changed MP3 to zero samples since not processing MP3, but may add some benefit
2. Maximum CPU usage on Restoration
3. Enabled Dequantizer and maxed all quality settings
4. Change pre-amplifier to -13.56dB (6dB+7.59dB) - this adds 6dB of additional headroom for dynamic range
5. Changed high-pass frequency from 25Hz to 15Hz, and Low-pass from 18,000Hz to 22,050Hz
6. Changed Advanced Clipper CPU strictness to 20 (maxed) and Medium Stop to 20 (maxed)
Just on a test of Britney Spears "Stronger" (ok, don't judge me :lol: ) Looking at the amplitude statistics the difference is pretty impressive...
Dear friend...help me..what software use for generate this images report? Thanks
