Hello again,
In addition to this topic…
viewtopic.php?f=3&t=7087
… I was asked there to share my current ST settings, what I would like to do now. According to the topic title “Developing…” I am still interested in further improvements to my rather few settings so far.
These settings include the declipper with max. CPU usage for best results and the Natural Dynamics effect with a strength of 0.50. Before I start the effect, I lower the volume to a total db of -12. E.g. if the song (or album) has a dynamic range of 5 db, I lower the volume by -7 db. That is more than enough headroom before using ST. There might remain some “clipped peaks” in the declipped waveform, which have no effect to the sound in my opinion. These peaks are obviously “calculation errors” of the declipper but I do not know how to cut them out without having a negative effect on the final output. If someone knows, please let me know. (this would make sense to get a more precise dynamic range calculation after using the ST effects)
In addition to these settings and as I am still not really convinced of the treble sound, I use a freeware shelving EG with a very subtle mid-side change change effekt of +1.5 db beginning at 3.4 KHz, which really improves treble sound itself as well as the stereo effect, which broadens slightly.
These both tools together already create some really excellent results. Surely not on every clipped/compressed song, but if the original production is good enough, I’m really delighted with the results so far.
If someone has further ideas for improvements to get a “most audiophile” sound (clear, natural, as you like to calll it), I would be very interested in. If you add changed presets here: please try to describe shortly what you have done and, if possible, do not make too many changes in one go, because in that case it becomes really difficult for me to understand (and listen), what each effect change is doing. For that reason I have not tested too many ST effects so far. Subtle effects I do not hear on my PC, each time I have to burn a CD and listen to it on my real equipment.... and very often in the past, a good impression on the first listen is gone three days later.... which shows how difficult it is to get a real natural sound.
