Post new topic  Reply to topic  [ 53 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Sun Sep 13, 2015 2:07 am
Jesse,
Just wanted to say that the Minnesota Lakes version is great! It makes all music sound very clear and open. Please don't forget about these presets and continue to update them as ST gets updated.
Thanks again!
I totally agree.
In some songs seem to have problems of compression (some sounds come and go).
Improved dynamics in mp3 files
If stored in wav
I completely love the dynamics in the preset but it doesn't always sound consistent. If you try “Muse – Map of problematique” everytime the singer sings a word that starts with an S or an F it sounds like somebody is adjusting the treble button. I'm talking about the lakes version in 7.73
Yes! I hear this as well, i only didn't want to be the first "faultfinder" who mentioned this. I notice this effect in nearly all material, not just some songs. But I see nothing to improve there fom Hans's side. There are so many possibilities in adustments to suppress those effects:
-Band couplings in various ways
-Max Attack/ Max Release Parameters in the analog mode to prevent bands from "running away"
-slope sizes of the bands.
You only have to use them!
I am very sorry, but a preset that has these artefacts can never be a good preset in my opinion!
Just use the possibilities that are inserted into this greatful tool and all those effects are gone!
The Multiband sections are so great now like they are!
Sorry for my directness, I only say what I hear.
Regards,
Robert
PostPosted: Tue Sep 15, 2015 7:03 pm
Robert,
I know personally that Jesse worked for hours, literally, like 10+, to try to tweak out the ill effects. He also reported to Hans the exact problem(s). It's up to Hans now to prioritize and fix the issue.
Hot Country Hits!
PostPosted: Sat Sep 26, 2015 10:02 pm
Robert,
@Timmywa
I don't see fixing these ill effects anywhere on the todo list in the current beta. Do you know when those will be addressed?
@Jesse
Thanks again for all your work and sharing the preset, but is there any tweaking you can do for the the lakes version in the current build? I listen to it anyway because the dynamics are just amazing :D but you must have also noticed the ducking in the current build right?
PostPosted: Mon Sep 28, 2015 7:47 pm
I just released Minnesota v0.01.57 for Stereo Tool v7.74+ on the top of the first page of this topic.
Changes:
  • North
    • Fixed broken Burst Protection settings, more dynamics
    Lakes
    • Added new "Spectral Balance" multiband feature, improves attack/release characteristics of AGC and Multiband
    • Moved the multiband's limiters before its compressors, improves attack characteristics
    Twin Cities
    • Added new "Spectral Balance" multiband feature, improves attack/release characteristics of second Multiband
    • Moved the second multiband's limiters before its compressors, shouldn't have an effect
PostPosted: Mon Sep 28, 2015 8:24 pm
Looks like Google disabled the shortened URL.
PostPosted: Mon Sep 28, 2015 8:39 pm
Updated download link. Weird...
PostPosted: Tue Sep 29, 2015 12:45 am
Jesse....
It would be possible to use more descompression, especially in the subwoofer bass drum?
PostPosted: Tue Oct 27, 2015 8:46 pm
Hi Jesse,
Version v0.01.57 is definitely an improvement, it still has the ducking problem though. I hope you'll be able to improve it further.
PostPosted: Sun Jul 10, 2016 1:30 am
@JesseG, I just wanted to report that the North preset, is the best I've heard in StereoTool.!
I use this preset for streaming and sounds great!
It is a sound hurts so low for FM, is there any way to increase the loudness?
PostPosted: Mon Aug 01, 2016 1:13 am
Jesse,
Hey, perhaps the song track 'Father of Mine' by Everclear may help sort out the ducking issue... After processing on Lakes setting, the vocals are super clear, but as soon as the instrumentals start, his voice goes way deep behind everything else, and its almost hard to hear the guy...
Oh, I also notice the setting uses simple clipper instead of the advanced clipper. Is this by design, or has the preset not been updated for the advanced clipper?
Also, on the HD settings, there are a couple settings that look like they could be increased for maximum quality, but again was not sure if this was on purpose (I use it offline, so no constraints on time/cpu power :) )
The overridden settings below did a fantastic job with Death Magnetica... Although the processing speed for track 2 - end of the line, increased from taking about a minute to just over 14 minutes to process, about 1/2 of real time.
[Absolute Highs]
Auto detect highpass filter=0
Before Multibands=After Multibands
Difference=0
Effect strength=1
Highpass filter follows Delossifier=1
Highs - 1 Band (7.85 BETA008)=0
Highs - Band distance=0.5
Highs - Block during collection of shape=0
Highs - Oversampled=1
Highs - Shape width=32
Highs On=1
Maximum working above=9200
Peak Distance Maximum=1000
Peak Distance Multiplier=2.5
Slope up to=11025
Threshold (gate)=0
[Declipper]
Amount of peak samples to remove - long term=0.310000002
Amount of peak samples to remove - short term=0.620000005
Analog input=0
Clipped if below short term margin=0.270000011
Clipped if below short term margin Enabled=1
Clipping straight line margin=0.449999988
Declip if (type)=3
Declip if type 4 long term margin=0.919999957
Definitely clipped if below (relative)=0.970000029
Do not allow restored peaks to be lower than clipped signal=0
Do not reconstruct if reconstructed signal resembles original - texture threshold=0.899999976
Do not reconstruct if reconstructed signal resembles original - threshold=0.899999976
Dynamically increase maybe clipped level=1
Dynamically increase probably clipped level=1
Enabled=1
MP3 input=1
MP3 margin=1
MP3 number of samples=0
Maximum expected distortion level=0.75
Maximum restored peak=4
Maybe clipped if below (relative)=0.670000017
Not clipped if below (absolute)=4095
Only declip if clipping histogram spike is symmetrical=0
Only declip if tilt can be determined=0
Probably clipped if below (relative)=0.800000012
Quality=99.999984741
Reduction precision=1
Tilt default level=0.016666651
Tilt level detection enabled=1
Tilt maximum adjustment per measurement=0.027777778
Tilt maximum level=0.25
Tilt minimum level=-0.25
Veil after spike down speed (dB/ms)=1.159999967
Veil margin=0.899999976
Veil normal down speed (dB/ms)=0.439999998
Veil speed drop time reduction time after spike (ms)=1.620000005
[Delossifier]
Difference=0
Enabled=1
Left channel only (testing)=0
Maximum relative volume reduction=2
Pre-ringing killer enabled=1
Spectral hole filler - Detect MPEG=1
Spectral hole filler - Difference=0
Spectral hole filler - Enabled=1
Spectral hole filler - Minimum frequency=600
Spectral hole filler - Reconstruct top part=1
Spectral hole filler - Reconstruct top part if likely=0
Spectral hole filler - Reconstruct top part if likely - Slow rise=1
Spectral hole filler - Reconstruct top part if likely - Slow rise - Avoid highs flutter=1
Spectral hole filler - Reconstruct top part if likely - Slow rise - Avoid highs flutter - Stronger=0
Spectral hole filler - Show histograms=0
Spectral hole filler - strength=1.410000205
Spectral hole filler - threshold=4.999999523
[Dequantizer]
Block sizes=All
Enabled=1
Input bits=16
Maximum reduction=2
Quality=1
Reduction start=1
File comment: All settings maxed (many beyond the limits in the GUI interface)
Jesse Graffam - Minnesota Lakes v0.01.57 HD_MAX Qualityv2.sts [87.65 KiB]
Downloaded 304 times
