There are so many new presets that I'm getting lost... So, I want to ask your help to decide which presets should be included in version 7.51. At the same time I want to clean up old existing presets.
Removal of presets
I will remove all presets that still use the old multiband (those below and starting with Bojcha - Eu4ria II in all categories). But if there are others that I should remove, let me know. Stefan van der Wiele has already asked me to replace Hard Solution by his new Levels preset.
New presets
I have attached a .zip file with a lot of new presets that were posted here. I have removed some that clearly failed on some material, and normally that means that I only have a few left - but this time the number is a lot bigger - you preset makers appear to be getting better at it
In the end, it's not useful to have 5 nearly identical presets built-in, so I really only want to keep those that sound good and add something.
The following presets will definitely be included:
Bojcha - Unveil (FM & web, and HvZ mod, although that's not the one included in this list)
Jeff Prins - The Return (which is not yet finished, final version should arrive within a few days)
Jeroen Platenkamp - Centurion (FM & web, a somewhat strange preset which many people seem to like).
About Preda Liviu Dj-Liviux's preset (which is a mod of a preset by HC34): I kinda like this preset (it sounds good, and it's based on FM sound in Romania) but it does really weird things and I don't know if it fails on some material.
Note: Please use the zip file on top, I removed a number of presets today.
