PostPosted: Thu Apr 30, 2009 10:43 pm
I cannot find the place to put the .sts files. I installed Stereo Tool (Winamp version, on Win XP) to C:\Program Files\Media Monkey and it works great but I don't see any trace of Stereo Tool in the Media Monkey folder or the Plug-ins subfolder. Where is it?
PostPosted: Thu Apr 30, 2009 11:58 pm
Sorry for replying to my own message, but I did find the StereoTool .dll in the Media Monkey folder.
I still don't know where to put the sts files.
Please help.
Thanks.
(Great software btw!)
PostPosted: Fri May 01, 2009 12:20 am
Welcome Treeves,
You can store the STS files wherever you want. I usually put then in C:\, but that's probably not a very good advice :? - so just create a directory for it somewhere.
PostPosted: Fri May 01, 2009 1:23 am
Wow.
Sorry for my first question being a dumb one! I should have tried it _before_ asking.
Thanks for the quick answer!
