Hello Bojcha,
The loudness of your preset is my preference, use similar values, does not generate too much ear fatigue (mainly female audience). It also lets you hear the music more detail, that of otherwise lost much.
For my taste, are using too much limitation on the MB, the ratios would decline slightly. It would sound more open, especially in the mids.
As always, good job!
tnx..
Limiters in MB are actually not limiters. They are clippers. Meaning, it will not strictly limit certain peek to adjusted level, some will go through.
Also, because decent range in MB, for audio with soft mids limiters need to be there for sudden bursts, since MB is relatively slow.
I missed this part, in the days that I was not ... was about to ask about the limiter to Hans, because he understood a lot like acting, now I understand.
We need to work as a limiter to use to lower compressor overshoot.
I have not had time to test the new beta, but until the previous version is very difficult to keep in place when mids lacking bass.
In my preset, I had to modify various settings to try to keep them, using light compression.
I'll try a new beta soon.
