Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: GAP - Storm
PostPosted: Fri Feb 17, 2012 4:54 am
I leave a new preset, which emphasizes more dynamic presence throughout the spectrum. good vocal presence, greater body low and high clearly defined.
The single band compressor, was used as a second AGC after the MB, to maintain a loudness without changing the dynamics of the signal.
Well, the rest will find out by testing ... :idea:
Comments are welcome, to improve ;)
Edit: (Read Last Post for News)
Last Version: GAP_Storm_v1.01 (2012-06-07) download/file.php?id=510 New!!! for ST v6.31 beta 20
GAP_Storm_v0.1.zip [4.16 KiB]
Downloaded 955 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Mar 05, 2012 4:59 am
New version,
- Improved low frequency range.
- Bass AGC
- Small changes in the high
Tested with beta 6.22 (build 21) ;)
GAP_Storm_v0.2.zip [4.18 KiB]
Downloaded 830 times
by GAP
PostPosted: Tue Mar 20, 2012 5:21 am
Some minor changes, adjustments in some levels.
Test it! :D
GAP_Storm_v0.3.zip [4.08 KiB]
Downloaded 802 times
by GAP
PostPosted: Fri Mar 23, 2012 1:00 am
Change in the bass, more dynamic and more impact.
Try it. ;)
GAP_Storm_v0.4.zip [4.17 KiB]
Downloaded 849 times
by GAP
 Post subject: Re: GAP - Storm
PostPosted: Sun Apr 15, 2012 6:09 am
I have here a new version adapted to the new version v6.30 ST.
Test it and make comments. ;)
GAP_Storm_v0.5.zip [4.16 KiB]
Downloaded 847 times
by GAP
PostPosted: Sun Apr 22, 2012 5:58 am
I have made some arrangements in the treatment of low, for better punch and depth.
Also some subtle improvements in the high places.
enjoy! :D
GAP_Storm_v0.6.zip [4.25 KiB]
Downloaded 824 times
by GAP
PostPosted: Tue May 01, 2012 6:56 am
I corrected some details in the bass and highs, so this update. :mrgreen:
GAP_Storm_v0.7.zip [4.19 KiB]
Downloaded 836 times
by GAP
PostPosted: Sat May 05, 2012 6:05 am
After several attempts to continue using it, I decided not to use the Compressor SingleBand ... makes it removes dulling the highs and bass dynamics.
Try the new configuration and you will see the difference, it is worth trying.
The sound is now more dynamic, clean and transparent. :o
GAP_Storm_v0.8.zip [4.19 KiB]
Downloaded 787 times
by GAP
PostPosted: Tue May 08, 2012 4:46 am
I made ​​some fine adjustments on the version 0.8, mainly the bass and highs refining. I added a little more on the Loudness Clipper, I have lost a little boost bass levels and gone a few dBs Target of AGC, to give more dynamic and clarity to the whole spectrum.
I have reached the desired sound with this release.
Same resources of those who believe that there is always more.
Here I leave once again another preset. ;)
PS: Sorry for the latest updates so close together! :mrgreen:
GAP_Storm_v0.9.zip [4.19 KiB]
Downloaded 819 times
by GAP
PostPosted: Mon May 21, 2012 5:40 am
Several changes in this version.
The first 3 bands bass, a little more compression (more louder and deeper)
About 2.50 dB over the AGC output level to the MB.
In the last 3 bands, rose slightly but the Speed ​​Up, and anything else the clipping force.
Increased release of the mids bands, should be more natural voices.
Changes in loudness, bass and more clipping control.
Tested with version 6.31 beta 6. ;)
Can you comment without prejudice :lol:
GAP_Storm_v0.95.zip [4.17 KiB]
Downloaded 917 times
by GAP
