PostPosted: Sun Mar 24, 2024 1:25 pm
I was trying to make Stereo tool suitable for an old laptop I have and I came up with this preset. It uses up to 30% on a dual core celeron@1.5Ghz, depending on your "Resource usage" settings in Application settings.
Latest version from 05.05.24.
Martin Petrov - Martin Petrov_s Universal Preset Laptop Version - 2024-05-05.sts [167.32 KiB]
Downloaded 22 times
PostPosted: Wed Mar 27, 2024 2:48 am
Dam this setting is amazing 2nd best setting IMO. Suggestions turn down the bass and mid highs just a little and it will be perfect.
Phat Beats Radio Playing the best Rap RnB Soul Funk Reggae Chillhop Acid Jazz Triphop Blues from the 70s to early 2000s streaming at 192kbps Opus over 165k tracks in the playlist
PostPosted: Wed Mar 27, 2024 5:15 am
Thanks, can't really compete with the presets made without low CPU usage in mind, but for this scenario it really can't get much better than that. Here's an updated version with the changes you suggested. :) If it's not right, then I could add another band to the multiband processor to make highs compression more precise at the cost of just a little more cpu usage.
Martin Petrov's Low CPU usage preset v2.sts [165.2 KiB]
Downloaded 68 times
PostPosted: Thu Mar 28, 2024 3:36 am
It sounds better one more small suggestion it is like 2db too loud
PostPosted: Thu Mar 28, 2024 8:49 am
Just double-checked the advanced clipper and the volume there seems to be set fine. The post-processing/post-amp volume is a matter of personal needs/preferences and can be set accordingly in "processing" section.
Actually when i first posted the second version, it was set at -6 by mistake and then I re-uploaded it with the right volume. So if anyone downloaded it earlier and found it quiet, should adjust the post-0amp ot just download the fixed version. :)
PostPosted: Mon Apr 15, 2024 5:34 am
Like Bojcha I decided to experiment with 3 bands on the compressor and I got even better results than in my previous version. The AGC still uses 4 bands as it has close to 0 impact on cpu usage. :)
Martin Petrov's Low CPU usage preset v3.sts [165.76 KiB]
Downloaded 39 times
PostPosted: Tue Apr 16, 2024 5:02 am
And v4 with further improvements i made in AGC, it now has more natural sound image. :)
Martin Petrov's Low CPU usage preset v4.sts [165.75 KiB]
Downloaded 68 times
PostPosted: Wed Apr 17, 2024 3:06 am
IMO this version Mids Highs and Treble are little to high for my liking
