 Post subject: TNN Radio Preset
PostPosted: Fri Dec 01, 2023 1:44 am
Hello there,
I'm trying to make a preset to sound like the station https://tnnradio.com
Can anyone replicate the sound of this station or advise me which preset would be the closest? Thanks in advance!
-Brady
 Post subject: Re: TNN Radio Preset
PostPosted: Fri Mar 08, 2024 2:43 pm
Just bumping this because it didn't get any replies. Does anyone know what preset would be the closest to how this station sounds or can anyone help me create one?
PostPosted: Fri Mar 08, 2024 2:49 pm
Have you tried the "KX The Edge" preset from the integrated presets? The sound reminded me of this preset, it might be close.
PostPosted: Fri Mar 08, 2024 3:18 pm
I'll give it a try!
PostPosted: Tue Mar 12, 2024 1:40 pm
Just try this one. In country music You need guitars more louder then the other styles. I have tested mentioned on a local steam, and for my ears sounds great for this kind of music. But this is my only own opinion. Good luck !
