Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
 Post subject: Over all good sound
PostPosted: Sun Nov 21, 2010 5:34 am
IF THESE SETTINGS DON'T WORK FOR YOU
Turn the FM transmitter settings off, I have it set for direct sound card output. Which should work, if it doesn't... dude idk.
Vibin and messin around with Stereo Tool.
Sounds good with dubstep, rock, hip-hop, and DnB.
-Skream
-Benga
-Disturbed
-Nas
-Black Eyed Peas
-Gorillaz
Winamp (latest one on this date)
Win7
No EQ
5.1 panasonic receiver Dolby prologic2 mode
Stock speakers
2x 150-watt 8" subs
1 passive 1 active.
[Common]
Pre amplifier=4.710000038
Post amplifier=1
Extra loudness=1.029999971
Extra loudness - Allow extra highs (advanced)=1664.001464844
Extra loudness - Punchy=0.75
Extra loudness - Max Punch peak=2
Extra loudness - Deep bass protection - Enabled=0
Extra loudness - Deep bass protection - Value=0.762500048
Extra loudness - Reflection strength=0.099999994
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=199.279998779
Bass protection - Deep bass boost=80
Bass protection - Raise clip level if highs get above=0
Bass protection - Maximum clip level raise=0
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=0.159999996
Relative noise gate level - Band 1=0.639344215
Relative noise gate level - Band 4=1.127659559
Relative noise gate level - Band 5=1.127659559
Relative noise gate level - Band 6=1.247190952
Relative noise gate level - Band 7=1.409638405
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=0.730000019
Attack speed=0.004095
Decay speed=0.011316806
Above Top Limiter=1
AGC RMS style Enabled=1
AGC RMS style Target RMS level=26670
AGC RMS style Remove remaining peaks above=1.720000029
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=45850
Attack speed - Band 1=0.000045645
Attack speed - Band 3=0.000037442
Decay speed - Band 1=0.002081846
Decay speed - Band 3=0.000610579
Dual band=1
Third band=1
Relative expected volume of highs=0.680000007
Relative maximum volume of highs=10
Relative maximum volume of very highs=0.910000026
Remove remaining peaks above (relative to maximum volume)=3
Enable smoothing=0
Smoothing time=0
Gating level=26569
Use ITU-BS.1770=0
Channel separation=0
Gating based on volume before Pre Amp=1
Lock bass to band 2 strength=0.5
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=3220
Maximum volume - Band 0=3560
Maximum volume - Band 1=3220
Maximum volume - Band 2=3900
Maximum volume - Band 3=4920
Maximum volume - Band 4=4580
Maximum volume - Band 5=4750
Maximum volume - Band 6=3560
Maximum volume - Band 7=4750
Maximum volume - Band 8=6440
Attack speeds linked=1
Attack speed - Band -1=0.035244137
Attack speed - Band 0=0.035244137
Attack speed - Band 1=0.035244137
Attack speed - Band 2=0.035244137
Attack speed - Band 3=0.035244137
Attack speed - Band 4=0.035244137
Attack speed - Band 5=0.035244137
Attack speed - Band 6=0.035244137
Attack speed - Band 7=0.035244137
Attack speed - Band 8=0.035244137
Decay speeds linked=1
Decay speed - Band -1=0.010666901
Decay speed - Band 0=0.010666901
Decay speed - Band 1=0.010666901
Decay speed - Band 2=0.010666901
Decay speed - Band 3=0.010666901
Decay speed - Band 4=0.010666901
Decay speed - Band 5=0.010666901
Decay speed - Band 6=0.010666901
Decay speed - Band 7=0.010666901
Decay speed - Band 8=0.010666901
Above Top Limiter=0
Clipping enabled=0
Postprocessing enabled=1
Flat frequency response enabled=0
Relative clip position - Band -1=3.545454025
Relative clip position - Band 0=4.128205299
Relative clip position - Band 1=2.571429014
Relative clip position - Band 2=1.985074759
Relative clip position - Band 3=1.985074759
Relative clip position - Band 4=1.985074759
Relative clip position - Band 5=2.278688431
Relative clip position - Band 6=2.571429014
Relative clip position - Band 7=2.571429014
Relative clip position - Band 8=3
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=20
Equalizer enabled=1
Equalizer position - Band -1=1.105262995
Equalizer position - Band 0=1.150537729
Equalizer position - Band 1=1.197802305
Equalizer position - Band 2=1.531645775
Equalizer position - Band 3=1.222222328
Equalizer position - Band 4=1.56410265
Equalizer position - Band 5=1.631578922
Equalizer position - Band 6=1.985074759
Equalizer position - Band 7=1.247190952
Equalizer position - Band 8=1.197802305
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=1
Stereo Boost Excessive Reverb Protection Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=17
AZIMUTH change speed=2
Image phase amplifier=1
Image width amplifier=1.889999986
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=20
Stereo Boost maximum amplification=4
Stereo Boost multiplier=1
[Channel Delay]
Enabled=1
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=22000
Highpass filter=0
[Bass Boost]
Enabled=1
Strength=0.425299972
Start lowpass frequency of input filter=100
End lowpass frequency of input filter=340
Start lowpass frequency of output filter=400
End lowpass frequency of output filter=700
Clip level=1
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=240
Start speed=3080
Number of rotations=7.329999924
Smoothness=0.919999957
[Final Limiter]
Enabled=0
Difference=0
Pre-amp=0.810000002
Pre-limiter enabled=0
Pre-limiter relative volume=1
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=18
RDS signal volume=9
FM overdrive volume=1.200000048
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - http://www.stereotool.com
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=0
RDS Artificial Head=0
RDS Compressed=0
RDS Dynamic PTY=0
RDS RadioText Enabled=0
RDS ClockTime Enabled=0
MPX Oversampling mode=Never
FM Transmitter Calibration - Phase shift 20 Hz=0.25
FM Transmitter Calibration - Phase shift 160 Hz=0.25
[Lossy compression output optimization]
Enabled=0
Spike Protation pre-emphasis time=0
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=0.419999987
Send to Winamp=Normal
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.200000003
ASIO Override channel 1=2
ASIO Override channel 2=3
 Post subject: Re: Over all good sound
PostPosted: Thu Nov 25, 2010 3:06 am
Not bad. I am trying out all my hip-hop/R&B now with this preset.
Thanks for sharing!
PostPosted: Tue Nov 30, 2010 4:54 am
Fixed up low bass issues.
Fixed stereo expansion.
Fixed -insert random stuff here-.
[Common]
Pre amplifier=2.299999952
Post amplifier=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.24000001
Extra loudness - Deep bass protection - Value=0.49849999
Extra loudness - Reflection strength=0.024899999
Hard limit output=0
[Noise Gate]
Enabled=0
Difference=0
Enabled=1
Difference=0
Attack speed=0.000150704
Decay speed=0.011267699
Above Top Limiter=1
AGC RMS style Target RMS level=33330
AGC RMS style Remove remaining peaks above=1.5
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=36000
Attack speed - Band 1=0.000003382
Attack speed - Band 3=0.000214871
Decay speed - Band 1=0.001828427
Dual band=1
Third band=1
Relative expected volume of highs=0.519999981
Relative maximum volume of highs=4.670000076
Relative maximum volume of very highs=0.230000004
Enable smoothing=0
Smoothing time=0
Gating level=41208.99609375
Use ITU-BS.1770=0
Channel separation=0.800000012
Gating based on volume before Pre Amp=0
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=7290
Maximum volume - Band 0=7290
Maximum volume - Band 1=6610
Maximum volume - Band 2=5760
Maximum volume - Band 4=3730
Maximum volume - Band 5=3390
Maximum volume - Band 7=4240
Maximum volume - Band 8=5590
Attack speeds linked=0
Attack speed - Band -1=0.111123256
Attack speed - Band 0=0.099227525
Attack speed - Band 1=0.093913741
Attack speed - Band 2=0.088971786
Attack speed - Band 3=0.012489186
Attack speed - Band 4=0.013990208
Attack speed - Band 5=0.017522397
Attack speed - Band 6=0.02393277
Attack speed - Band 7=0.02393277
Attack speed - Band 8=0.02393277
Decay speeds linked=0
Decay speed - Band -1=0.040594161
Decay speed - Band 0=0.039423939
Decay speed - Band 1=0.026004046
Decay speed - Band 2=0.021736465
Decay speed - Band 3=0.026004046
Decay speed - Band 4=0.040594161
Decay speed - Band 5=0.075276032
Decay speed - Band 6=0.075276032
Decay speed - Band 7=0.075276032
Decay speed - Band 8=0.075276032
Above Top Limiter=0
Clipping enabled=0
Flat frequency response enabled=1
Equalizer enabled=1
Equalizer position - Band 2=1.409638405
Equalizer position - Band 4=1.127659559
Equalizer position - Band 5=1.409638405
Equalizer position - Band 6=1.247190952
Center frequency - Band -1=43.06640625
Center frequency - Band 0=86.1328125
Center frequency - Band 1=172.265625
Center frequency - Band 2=344.53125
Center frequency - Band 3=689.0625
Center frequency - Band 4=1378.125
Center frequency - Band 5=2756.25
Center frequency - Band 6=5512.5
Center frequency - Band 7=10000
Center frequency - Band 8=15000
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=100
Extra phase shift=0
[Channel Delay]
Enabled=1
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=0
[Bass Boost]
Enabled=1
Strength=0.735599935
Start lowpass frequency of input filter=120
End lowpass frequency of input filter=270
Start lowpass frequency of output filter=290
End lowpass frequency of output filter=420
Clip level=1.842100024
Preserve louder peaks=0
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=240
Start speed=3080
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter relative volume=1.019999981
[FM Transmitter]
Enabled=1
Pre-emphasize=0
RDS signal volume=9
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=0
RDS Compressed=0
RDS Dynamic PTY=0
Enabled=0
Enabled=1
Device ID=Realtek Digital Output (Realtek
Volume=1
Buffer size=0.100000001
Send to Winamp=Nothing
Enabled=0
Volume=1
PostPosted: Tue Nov 30, 2010 5:14 am
I like this so far! Good job haven't found any problems yet.
PostPosted: Thu Dec 02, 2010 5:24 pm
Added stereo effects :O
CPU intensive.. I guess? O.o I'm getting 8% on my Q660 @ 3.4
Stereo Tool 5.02 b(idk :[ ) - Winamp DSP through BreakAway.
Source - Grooveshark through Firefox 4.0b7
Win7 x64
[Common]
Post amplifier=1
Extra loudness - Allow extra highs (advanced)=40000
Hard limit output=0
[Noise Gate]
Enabled=0
Difference=0
Enabled=1
Difference=0
Above Top Limiter=1
[Pre Compressor]
Enabled=1
Dual band=1
Third band=1
Enable smoothing=0
Smoothing time=0
Use ITU-BS.1770=0
Channel separation=1
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=4240
Maximum volume - Band 0=5930
Maximum volume - Band 1=5760
Maximum volume - Band 2=5250
Maximum volume - Band 3=4580
Above Top Limiter=0
Clipping enabled=0
Equalizer enabled=1
[Stereo]
Enabled=3
Stereo Image Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=100
Image width amplifier=1.559999943
Extra phase shift=0
Stereo Boost maximum amplification=2
[Channel Delay]
Enabled=1
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=0
[Bass Boost]
Enabled=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=240
Start speed=3080
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
[FM Transmitter]
Enabled=1
Pre-emphasize=0
RDS signal volume=9
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=0
RDS Compressed=0
RDS Dynamic PTY=0
Enabled=0
Enabled=1
Volume=1
Enabled=0
Volume=1
My subwoofers are on the floor about a foot behind me. One is directly behind me the other is maybe a foot to the left.
I feel like I'm at a rave, but no weird lights and weird people on drugs.
I've tested these settings with mainly:
Dubstep
House
Hardstep
Random youtube videos
A film project for school
RHCP
Kid Cudi
The Bloody Beetroots
Passion Pit
God Smack
Disturbed
Linkin Park (new)
other stuff I can't remember right now.
PostPosted: Wed Dec 08, 2010 7:47 am
Stronger bass hits, perfect for club music. (drum N' bass and such)
Fixed up the stereo effects so it doesn't invert. <-wtf that makes sense right? :| (I saw this issue while listening to a track by bassnectar, original had vocals on left speaker my settings pushed vocals to right speaker. Friggin weird dude!)
Lowered the RMS volume, I feel like this makes the amp do more of what its supposed to do... ya know.. AMP. Instead of the software pushing the levels to red your hardware can do it now!
I like this for night time listening more, living in a dorm means I have to keep my neighbors happy.
I've been watching Dexter a lot :geek: and I find that this preset helps control the "intense" scenes where the audio goes well beyond normal listening levels.
Tell me how it sounds for you :)
[Common]
Pre amplifier=2.289999962
Post amplifier=1
Extra loudness - Reflection strength=0.112399995
Bass protection - Clip level=70.269996643
Bass protection - Raise clip level if highs get above=9.010000229
Bass protection - Maximum clip level raise=6.760000229
Hard limit output=0
[Noise Gate]
Enabled=0
Difference=0
Noise level=0.649999976
Enabled=1
Difference=0
Attack speed=0.000010942
Decay speed=0.033865064
Above Top Limiter=1
AGC RMS style Target RMS level=23330
AGC RMS style Remove remaining peaks above=2.190000057
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=14400
Attack speed - Band 1=0.000002108
Dual band=1
Third band=1
Relative expected volume of highs=0.860000014
Relative maximum volume of highs=3.329999924
Relative maximum volume of very highs=0.140000001
Enable smoothing=0
Smoothing time=0
Gating level=21316.001953125
Use ITU-BS.1770=0
Channel separation=0.5
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=5250
Maximum volume - Band 0=6440
Maximum volume - Band 2=5590
Maximum volume - Band 4=4260
Maximum volume - Band 5=4070.000244141
Maximum volume - Band 6=4070.000244141
Maximum volume - Band 7=4460
Attack speed - Band -1=0.356728673
Attack speed - Band 0=0.126893312
Attack speed - Band 1=0.047562279
Attack speed - Band 2=0.012147781
Attack speed - Band 3=0.012147781
Attack speed - Band 4=0.012147781
Attack speed - Band 5=0.012147781
Attack speed - Band 6=0.012147781
Attack speed - Band 7=0.012147781
Attack speed - Band 8=0.012147781
Decay speed - Band -1=0.075276032
Decay speed - Band 0=0.075276032
Decay speed - Band 1=0.075276032
Decay speed - Band 2=0.075276032
Decay speed - Band 3=0.075276032
Decay speed - Band 4=0.075276032
Above Top Limiter=0
Clipping enabled=0
Equalizer enabled=1
Equalizer position - Band 3=1.127659559
Equalizer position - Band 5=1.127659559
Equalizer position - Band 6=1.325581312
Equalizer position - Band 7=1.127659559
Equalizer position - Band 8=1.247190952
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=90
Image width amplifier=1.440000057
Extra phase shift=0
[Channel Delay]
Enabled=1
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=0
[Bass Boost]
Enabled=1
Strength=0.551699996
Start lowpass frequency of input filter=80
End lowpass frequency of input filter=180
Start lowpass frequency of output filter=350
End lowpass frequency of output filter=480
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=240
Start speed=3080
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
[FM Transmitter]
Enabled=1
Pre-emphasize=0
RDS signal volume=9
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=0
RDS Compressed=0
RDS Dynamic PTY=0
Enabled=0
Enabled=1
Volume=1
Enabled=0
Volume=1
PostPosted: Wed Dec 08, 2010 1:11 pm
Oh I like this one! The only change I've made so far to keep those "intense" sounds completely under control is turn on the 75us USA pre-emphasis. Very good job! I don't see how it could be improved yet but if you find a way, go for it! Good stuff thank you
[Common]
Post amplifier=1
Hard limit output=0
[Noise Gate]
Enabled=0
Difference=0
Enabled=1
Difference=0
Above Top Limiter=1
[Pre Compressor]
Enabled=1
Dual band=1
Third band=1
Enable smoothing=0
Smoothing time=0
Use ITU-BS.1770=0
Enabled=1
Difference=0
Delay enabled=0
Above Top Limiter=0
Clipping enabled=0
Equalizer enabled=1
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=90
Extra phase shift=0
[Channel Delay]
Enabled=1
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=0
[Bass Boost]
Enabled=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=240
Start speed=3080
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
[FM Transmitter]
Enabled=1
Pre-emphasize=0
RDS signal volume=9
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=0
RDS Compressed=0
RDS Dynamic PTY=0
Enabled=0
Enabled=1
Volume=1
Enabled=0
Volume=1
PostPosted: Wed Dec 08, 2010 5:05 pm
I tried that out, and hot dam that sounds better!
But I don't have a registered version of Stereo Tool just yet.
Going to try and emulate the sound without using registered options :)
PostPosted: Wed Dec 08, 2010 9:43 pm
Yeah I have a registered version but not FM Radio registered so those features produce that sound every 12 hours or whatever. Good luck I look forward to your presets :)
EDIT: Ok so I changed 2 little things with the latest version of ST. Try it out and see what you think. I took the "bass" settings in multiband compressor from another preset and kept the bass boost on. See if you like it better or worse.
[Common]
Post amplifier=1
Hard limit output=0
Extra loudness - De-esser limit=65536
Extra loudness - Allow more distortion=0
Extra loudness - Highs burst strength=1
Extra loudness - New Bass Protection - Very deep bass filter frequency 1=150
Extra loudness - New Bass Protection - Very deep bass filter frequency 2=350
Extra loudness - New Bass Protection - Clip very deep bass at=0.899999976
Extra loudness - New Bass Protection - BassMid filter frequency 1=350
Extra loudness - New Bass Protection - BassMid filter frequency 2=750
Extra loudness - New Bass Protection - Clip BassMid at=1
Extra loudness - Voice vibrations - Highs feedback strength=1
Extra loudness - Voice vibrations - Never reduce bass below=0.400000006
Extra loudness - Voice vibrations - Multiply measured vibration level by=0.899999976
Extra loudness - Voice vibrations - Ignore vibration levels below=0.5
Extra loudness - Voice vibrations - Reduce sensitivity for non-constant sounds strength=1
Extra loudness - New Bass Protection - Strict clipping=1
Extra loudness - New Bass Protection - Strict clipping - More strict=0
Extra loudness - New Bass Protection - Strict clipping frequency 1=250
Extra loudness - New Bass Protection - Strict clipping frequency 2=350
Extra loudness - New Bass Protection - Strict clipping - Clip bass at=0.949999988
Extra loudness - New Bass Protection - Strict clipping - Clip Punched bass at=0.949999988
Extra loudness - New Bass Protection - Strict clipping - Never dynamically raise bass level above=0.800000012
Extra loudness - Dirty Bass=0
[Noise Gate]
Enabled=0
Difference=0
Enabled=1
Difference=0
Above Top Limiter=1
[Pre Compressor]
Enabled=1
Dual band=1
Third band=1
Enable smoothing=0
Smoothing time=0
Use ITU-BS.1770=0
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=3900
Maximum volume - Band 0=7460
Maximum volume - Band 1=8470
Attack speed - Band -1=0.000129997
Attack speed - Band 0=0.000129997
Attack speed - Band 1=0.000129997
Decay speed - Band -1=0.000999812
Decay speed - Band 0=0.000999812
Decay speed - Band 1=0.000999812
Above Top Limiter=0
Clipping enabled=1
Relative clip position - Band 0=3
Relative clip position - Band 1=2.508771658
Equalizer enabled=1
Equalizer position - Band -1=0.694915175
Equalizer position - Band 0=0.801801801
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=90
Extra phase shift=0
[Channel Delay]
Enabled=1
Left Delay=0
[Output Filter]
Enabled=0
Highpass filter=0
[Bass Boost]
Enabled=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=240
Start speed=3080
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
[FM Transmitter]
Enabled=1
Pre-emphasize=1
Pre-emphasis time=75
RDS signal volume=9
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=0
RDS Compressed=0
RDS Dynamic PTY=0
Enabled=0
Enabled=0
Volume=1
Buffer size=0.305000007
Send to Winamp=Silence
Enabled=0
Volume=1
[FM Hiss]
Enabled=0
Difference=0
FM median pos=25
FM measure max multiplier=2
FM reduce=150
FM delay=2.5
FM delay median=7.5
PostPosted: Thu Dec 09, 2010 12:16 am
Did you copy the code over properly?
I just tried it and stereo tool just resets itself.
I'm running the latest beta.
