PostPosted: Sat Dec 08, 2018 8:04 pm
Here is one super open and multi purpose preset.
StarGate_WEB-HD_RC1.sts
StarGate_WEB-HD_RC2.sts
StarGate_WEB-HD_Final.sts [346.61 KiB]
Downloaded 373 times
StarGate_FM_Final.sts
Sorry, need to upload FM version again with one important fix. "Final2"
StarGate_FM_Final2.sts [371.17 KiB]
Downloaded 323 times
Here is StarGate Ultra FM. Be sure to load "All Audio and FM Settings" it will change your RDS Settings, so backup it.
Preset is prety loud so please tell me if you notice any bad behaviour.
StarGate_Ultra_045FM_RC1.sts [373.92 KiB]
Downloaded 213 times
 Post subject: Re: StarGate HD
PostPosted: Sun Dec 09, 2018 7:38 pm
Updated to RC2
Clean up and fine tuning limiters. Phase scrambling on.
PostPosted: Mon Dec 10, 2018 11:34 pm
Noticing you're also using (the built-in version in the program itself) the multipath protection and mono bass instead of Limit Instead, which is more geared towards streaming and HD. Are you purposefully setting it that way based on your preference to the sound of those FM-based settings?
Hot Country Hits!
PostPosted: Tue Dec 11, 2018 2:48 am
Multipath is actually off at 180 (atleast it should be). I am using it only because 'mono bass' (Hans still does not want to put it somewhere else).
Limiting is used, check Pre-Limiter. Few peeks still got slightly clipped tho.
Why mono bass..
I am really sensitive on phased bass. There are many tracks that have that stereo effect and/or channel phased Bass. To me, way more better and louder bass is when it's mono. In this case i put it to about 60Hz so still some bassy sounds that gets stereo. It's same with speakers, if there is a little phase between them bass will come less loud. So speakers need to make same amount of bass with exact same phase to not cancel each other. That's why we are sometimes surprised how some crappy 2.1 speakers system sounds good on bass.
About Pre-Limit..
I tested it again recently and found that it's doing good job of protecting other tones from bass, especially on bursts, and in same time it's limiter rather then only clip stage.
So none of this does not need to be true or important. Question is, How does it sound for you?
PostPosted: Tue Dec 11, 2018 8:39 pm
Good job, like it. Similar to the Sesame-preset which I used until now.
PostPosted: Tue Dec 11, 2018 9:03 pm
True. Sesame was my first attempt for open preset. This time i wanted it sligtly bigger and bit less loud. Also to use new features and new expirienced stuff :)
Also base for this preset is actually 7wonders.
PostPosted: Tue Dec 11, 2018 11:17 pm
Final Versions uploaded. FM and WEB/HD.
PostPosted: Wed Dec 12, 2018 11:37 am
PostPosted: Mon Dec 24, 2018 5:24 pm
Noticing you have legacy AGC enabled. Is the Current AGC having issues in your ears?
Hot Country Hits!
PostPosted: Mon Dec 24, 2018 7:33 pm
Yes. 'Current' does not have proper window, and no protection WB compressor. Also i dont like release shape in 'Current AGC'.
