Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: DynaRider
PostPosted: Fri Jun 15, 2018 10:18 pm
RC1 Preset. DynaRider WEB/HD/FM
Note: In Current beta WEB/HD version is wrong. It's just pulled from FM version.
DynaRider_v0.00.63-HD_ST_9.00_RC1.sts [105.39 KiB]
Downloaded 558 times
Some notes about preset usage:
- I maded MB2, BC and Clipper(Limiter) to work as one. That requests from user to change loudness level from MB2 "Drive" and not from "Advanced clipper" Currently level of MB2 Drive +1.40dB. I recommend it at 0.00dB. It should be all fine till +5dB, except some classic IMD.
Ofcourse it's possible to rise "drive" In Advanced Clipper. But since It's doing bad things in mid/mid-bass I maded 4-band limiter to not do that.
- AutoEQ is tuned (as much as i don't hear chamaleon effect), but by default it's OFF.
- As usuall on all my presets input level is ~-6dB. Any level will be ok tho, as much as there is some drive in AGC.
- "Mono Bass" (Multipath) is not part of WEB/HD settings (?) It's should be ON, Angle 180, Mono Bass ON, 77Hz. - Fixed
- Double check "Advanced Clipper" and "Relative Non-FM Loudness" are on 0.00dB! - Fixed
- To increse or decrese Bass, please do that from 1st band in MB2, "Band Mix" Level. Recommend -6dB (normal) up to +3dB (huge)
- Phase Delay Tuned, but by default OFF. (For those who loves that famous optimod touch)
RC2 -
- Fixed last band too fast and restless
DynaRider_v0.00.63-HD_ST_9.00_RC2.sts [105.4 KiB]
Downloaded 523 times
RC3 -
- More tuned last MB band
- Tuned BC for more warmer bass + more soft
- Added bit more deep bass
- Default MB2 Drive lowered by 0.1dB. Now at +1.30dB.
- settings for ST v9.01+
- a few minor fixes and improvements
DynaRider-HD-WEB_ST_9.01-plus_RC3.sts [105.62 KiB]
Downloaded 601 times
RC4 -
- MB2 Drive lower by 0.1 (again) +1.20dB default. No, 1.3 is ok. better to..
- Set main MB1 Density to -0.95dB
- Crossover for Band 2 in MB1 slightly changed. (slightly more warm punch)
- Band 2 in MB1 Attack bit slower.
- Changed Soft Bass Clipper. Stronger but without killing most demanding bass tracks.
- Huge update for MB1 Attack. Fully new universal and adaptive settings for any attack speed.
- Skip RC4.
RC5 -
- Fine tuning new and faster attacks.
- More tuning for Soft Bass clipper
- Other fixes and tunings
- FM version!
DynaRider-HD-WEB_ST_9.01-plus_RC5_Final.sts [106.06 KiB]
Downloaded 788 times
DynaRider-FM_50us_ST_9.01-plus_RC5_Final.sts [109.84 KiB]
Downloaded 628 times
 Post subject: Re: DynaRider
PostPosted: Fri Jun 22, 2018 10:09 pm
Hi Bojcha,
I can't find the RC3 version of DynaRider in your post.
Would like to try it out :)
Kind regards
PostPosted: Fri Jun 22, 2018 11:19 pm
Hi Stefan, this is a to do list for Bojcha he will share his new (RC3) preset soon.
PostPosted: Mon Jun 25, 2018 8:52 pm
Sounds amazing, Bojcha!! Thanks!
Three Decades of Country!
PostPosted: Tue Jul 03, 2018 6:09 pm
The latest Beta, 004, killed your preset. It changed to no output as soon as I installed it. I didn't have any time to investigate, just switched to another preset.
PostPosted: Wed Jul 04, 2018 1:41 am
Here loads fine from file and also from preset list
PostPosted: Wed Jul 04, 2018 10:44 am
Where is RC 4?
Garbage in is Garbage out !
PostPosted: Sat Jul 07, 2018 11:33 am
@Bojcha can you upload RC 4 here
thanks u
PostPosted: Sat Jul 07, 2018 8:32 pm
I will very soon.. just to fix some small things.
PostPosted: Tue Jul 10, 2018 9:36 pm
Hi Bojcha, when will you upload RC4?
