PostPosted: Mon Nov 21, 2016 11:06 pm
It is time :) :)
I believe that it is possible to have 11+ dbr of power on your FM mpx signal with loud and as clean as possible sound with the latest version of stereotool ( latest beta )
Can i prove this ? :oops:
11+ dbr of loudness on FM at 75 khz ? ( even 51 khz ...for multipath distortion prevention without stokemask ) :o
LET'S PUT SOME COMPARISON RULES. :roll: :roll: :roll:
1) mpx loseless file is at WAV format and has 2 demo songs with stereotool latest version with custom made preset.
2) mpx loseless file has 1 db less modulation for protection in case your soundcard driver or output settings are not correct.
So, add +1 db of voliume to compare at reference and if you connect this file on your FM testing transmitter stay at +- 75 khz modulation. :!:
the file has stereo pilot and rds feed !
https://www.dropbox.com/s/rmy2lm5lqrclb ... x.rar?dl=0
EDIT EDIT, FORGET THIS LINK , sample mpx is full of codec antifacts from resampling , bad mpx recording way. trying to make it correct.
( 2 demo songs and 1 mpx file by the transmitter , mpx recording was analog so please ignore noise and ringing on recording feed )
Check and compare my modulation with your presets and tell me if you have achieved better and louder preset than this :)
http://stream.cretanservers.gr/1045fm
Real time feed from transmitter is here : ( 128 kbps mp3 compressed live stream ...so there are overshoots here and it is only for a general sound picture )
real fm feed without overshoots is on the RAR file i ve uploaded.
If you have no FM transmitter or MPXtool to check the WAV mpx file , just take a look at the realtime stream at http://stream.cretanservers.gr/1045fm
IS IT LOUD ? IS IT CLEAN ? ( stream is - 3 db , so compare it at 0 db , not at -3 :)
CAN ANYONE MAKE A +11 dbr loud preset with stereotool ?
untill now i believe that i am the only one who have made this HIGH DBR PRESET.
( cleaner than ever )
PostPosted: Tue Nov 22, 2016 1:25 am
Here I listen to a saturated audio, too much I say, if it is a mistake let me know, I hope you share your preset.
PostPosted: Thu Nov 24, 2016 5:33 pm
Please downmix the 192 kHz MPX file to mono. I had to downmix it because it didn't work in MPXTool.
Anyway, the bass is very distorted - I can clearly see squarewaves.
Set the reference level in MPXTool to -1 dB instead of default -3dB to get 75kHz peak deviation when listening.
Why you left the pre-emphasis on on your stream?
PostPosted: Sat Nov 26, 2016 1:06 pm
How much this preset costs???? I want 100 of copies, so I will be able to give radio stations a good example of bad processing...
My radio station
http://amradio.ddns.net
PostPosted: Sun Apr 01, 2018 6:54 pm
Brb headphones exploded ...
PostPosted: Mon Apr 02, 2018 6:59 pm
Uh... no
I wonder if his preset uses the Declipper. :twisted:
PostPosted: Mon Apr 02, 2018 10:19 pm
Can this be moved to the presets forum?
Hot Country Hits!
PostPosted: Tue Apr 03, 2018 1:11 am
Wow,
you where RIGHT
thanks for the feedback
by the way , i believe NOW that i ve cleaned up all the mess.
it was all overdriven by the wrong way.
the key is to FIRST bypass everything and start from AGC and start to boot stage by stage.
everything was wrong , :)
now , i believe i ve made a clean as possible HIGH LOUDNESS FM preset.
check it now for 2 or 3 songs to be sure :oops:
bitrate is mp3 128 ...keep that in mind ..( high loudness 11 dbr is on FM , not on this loosy codec :)
this stream is FM BROADCAST
http://stream.grap.gr/1045fm
PostPosted: Mon Apr 09, 2018 10:40 pm
No, you just wrongly edited my preset.
PostPosted: Mon May 07, 2018 6:54 pm
I think i got higher loudness than this preset with my Omnia 9.
http://10.stmip.in:8252/listen.pls?sid=1
Sorry camclone, that's not a good preset for FM broadcast or HD, You should use it on AM.
Need Help? Call me, I can help you have a better sound with your actual audio processor, Analog? Unknown Brand? No Problem At All!
