Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: SoundReturn by GAP
PostPosted: Wed Apr 08, 2020 2:53 pm
Thanks for the comments, I will review and soon I will do an update.
It has been a long, long time ... but hey, the coronavirus and quarantine :) , helped me to have a little time to go back ... I have updated the preset to v9.40, activating new features, I hope you like it and if anything they don't like tell me ;) ...
Thanks to all the comments for expressing just what I am looking for in my preset's.
I just tested the newest version on my Shoutcast stream the computer running the radio automation program is hooked up to a Kenwood KR-5030 70s stereo receiver with Polka Audio floor speakers. V6 is decent but not that great I like v4 best. V6 volume is like 3 to 4 db lower bass is like 20% to 25% lower and mids and high is also like 15% to 20% lower than v4. V4 is amazing IMHO V4 is the best for Stereo Tool settings I have ever heard. V4 makes my 96kbps AAC+ stream sound like 35% to 40% better pm for the link to the stream.
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Apr 13, 2020 2:14 am
Some fine adjustments to bass and levels ;)
Tested with version 9.40
GAP_SoundReturn_v0.7.sts [120.49 KiB]
Downloaded 959 times
by GAP
PostPosted: Sun Apr 19, 2020 12:32 am
V 7 is the 2nd best version I am still rolling with v 4
7 the bass is turned down like 35% and the mids and highs down like 25%
V 4 if you like a decent amount of bass and good punch sound
V 7 if your not that much of a bass fan and still want a good warm sound with punch
Phat Beats Radio Playing the best Rap RnB Soul Funk Reggae Chillhop Acid Jazz Triphop Blues from the 70s to early 2000s streaming at 192kbps Opus over 165k tracks in the playlist
PostPosted: Sun Apr 19, 2020 2:46 am
@DJboutit: Thanks for the analysis !!!
by GAP
PostPosted: Sun Jun 14, 2020 4:54 am
It is possible get more final update to these settings??
PostPosted: Wed Aug 04, 2021 2:37 am
Any chance to get one more update
Suggestions turn up the volume 1 to 2 db increase bass 8% to 10% and increase mids highs 10%
Treble is just fine
PostPosted: Thu Feb 03, 2022 4:24 am
Would it be possible to get Version 4 updated for Stereo Tool 9.70 this is the version I am running. It would also be nice to get the setting update to check my previous post for the suggestions I have made.
PostPosted: Fri Sep 16, 2022 6:07 pm
Any chance this can be put in StereoTool? It has lots of other random user submitted presets, this sounds better than some of them.
PostPosted: Tue Oct 18, 2022 4:52 am
Are you saying you think these settings ahould be a default preset that is part of Stereotool??
PostPosted: Sat Oct 22, 2022 8:16 am
No chance. This preset is bad. It has serious problems and don’t sound good…
https://fmfeeling.com
