Here's my latest preset in the "Aussie Dreams" suite of presets.
It's based on my original Alpine Dreams & was just going to be a modified/updated version of that, but I modified so many settings & changed the sound, I thought I'd rename it to something new.
I've done some unconventional things with various settings, & it's quite balanced across the spectrum, with an unprocessed/natural sound.
I currently have it running on air on FM, & as a web stream.
Because it's quite balanced across the spectrum, it sounds good (I think), on just about any listening device, be-it computer or phone via web stream, or terrestrially on FM, using a small transistor radio or clock radio with a small cheap speaker, through to a multi speaker HiFi system with sub woofer.
I've had great feedback from my PD & Station manager about the sound & how clear/clean it is too, only problem is, it's showing up how bad some of our poor quality source material is (which is next on the replacement list).
I finished the preset off & it's running on ST 8.14, so it probably sounds best using that, I haven't tested it on anything before ST 8.12, so can't say if it works as well using old versions?
Have a listen & comment, because I'm interested in other's thoughts.
GLENN PRITCHARD - CITY DREAMS.sts
