PostPosted: Sun Oct 09, 2016 2:07 pm
Aussie - Super Charged Dreams (Beta v1).sts
Hey Toolies,
Have you the need to be really loud on your FM transmission and maximise limited transmission power.... Well this config may be the answer.
As its named, its super charged and its bass will rattle your windows with the rumble of the super charger.
It runs up to 8dB in the FM Music Power levels, a good 2dB higher than most profiles..
The profile attached is setup for FM. You may need to goto "Configuration" and set your Sound Cards as required.
Feedback most welcome.
