 Post subject: Everyday use ?
PostPosted: Thu Dec 10, 2009 7:14 pm
What kind of setting would you use just to improve sound for your everyday use.
 Post subject: Re: Everyday use ?
PostPosted: Fri Dec 11, 2009 1:52 am
Well, this is of course very personal, but I usually listen with one of the "General presets". I made "Constant volume, increased stereo - with reduced noise" exactly for this purpose. Some other presets made by others for several different types of music are also available.
In general:
- Use mild (non-aggressive) settings for the multiband compressor. Set it to "Compress" rather than "Limit".
- DO NOT use Loudness, that only hurts the sound quality (and you have a volume button anyway)
- I usually use Stereo Boost to increase the stereo.
